List of Dash/Interior lights?
Discussion in '1st Gen. Tacomas (1995-2004)' started by eimkeith, Nov 18, 2018.
  1. Nov 18, 2018 at 6:34 AM
    eimkeith
    eimkeith [OP] Well-Known Member
    J Keith
    '96 4Runner, '03 Taco
    Hey guys,
    I spent the day yesterday doing odds & ends to the new '03 Tacoma, and part of that was replacing the instrument cluster bulbs. As it turns out, I did not have the correct bulb in inventory for the HVAC controls, so I have to do those on round 2.
    Additionally, I suspect there are numerous other controls that should be illuminated (there are in my '96 4Runner, anyway) - but I couldn't find a comprehensive list of bulbs and bulb placements searching through the TW threads.
    I'd like to take care of EVERYTHING on the next round, so I'm researching the bulb types and quantities (incandescent) so as to not need a round 3.
    I did find the following in another post, but I've amended it to include switches that I suspect should also be illuminated - can you guys confirm and/or amend this list?
    1. Low Beam Headlight Bulb Size: 9003/HB2
    2. High Beam Headlight Bulb Size: 9003/HB2
    3. Parking Light Bulb Size: 168 or 4157NALL
    4. Front Turn Signal Bulb Size: 4157NALL
    5. Rear Turn Signal Bulb Size: 1156
    6. Tail Light Bulb Size: 1157
    7. Stop Light Bulb Size: 1157
    8. High Mount Stop Light Bulb Size: 168
    9. License Plate Bulb Size: 194
    10. Back Up Light Bulb Size: 921
    11. Front Sidemarker Bulb Size: 168
    12. Dome Light Bulb Size: DE3175 or 10W
    13. Step/Courtesy Light Bulb Size: DE3021 or DE3022
    14. Ashtray/Glove Box Bulb Size: 74
    15. Instrument Cluster Bulb Size (x4): 168/194
    16. HVAC Bulb Size (x3):
    17. (99) AC Button Bulb Size (x1): 88607-16010 - White base - 14V 0.065A
    18. (99) Hazard Switch/Diff Lock Switch Bulb Size (x2): 84999-10320 - Grey base - 14V 0.84W
    19. ECT Switch?
    20. (99) Passenger Air Bag Switch Bulb Size (x1): 90072-02005 - Brown base - 14V 1.12W
    21. anything I'm missing?
  2. Nov 18, 2018 at 7:06 AM
    02hilux
    Planet: EARTH
    Ashtray and glovebox are 74
    The hvac bulb are dealer only, it's a bulb built in with socket if you have the 3 bulb system.
    Cluster bulb are 168/194
  3. Nov 18, 2018 at 7:12 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    HVAC on my '99 are 2 # 74 mini bulbs. Most of the dash warning lights are also #74 mini bulbs except the low fuel warning which was slightly larger but a 74 still fit.
    Dealer only is crap. Those are the #74 mini bulbs and they pull out of that "built in" socket.
  4. Nov 18, 2018 at 7:18 AM
    02hilux
    Planet: EARTH
    Pre-01 hvac bulb are different
    Not on the 3 bulb system (01-04). Bulb is completely different. 74 are way too tall and the oe bulb have a flat bottom, no way a 74 will fit.
    I tried on my 02, you?
  5. Nov 18, 2018 at 7:22 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
  6. Nov 18, 2018 at 7:30 AM
    02hilux
    Planet: EARTH
    I know the bulb itself is not replaceable on the 3 bulb system (01-04). The bulb will not pull out. Power / connection pronge from the bulb is fed through the socket and wrapped around the socket.
    Op vehicle is a 96, so maybe on that part you're correct. Might be replaceable with bulb, but that's not the case on 01-04
    xtremewlr likes this.
  7. Nov 18, 2018 at 7:40 AM
    02hilux
    Planet: EARTH
  8. Nov 18, 2018 at 7:50 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    So they can be replaced, just not as easily. And if the 01-04 are anything like my '99, then getting the HVAC controls out to do that swap is a pain in the ass.
    02hilux likes this.
  9. Nov 18, 2018 at 7:56 AM
    02hilux
    Planet: EARTH
    Correct, if you plan on changing the bulb color it's doable. 01-04 bulb is also located inside the panel as well like pre-01, have to be patience and careful when prying the housing apart.
    But if you want to retain the factory color like me, you won't be able to find a replacement bulb beside the stealership or maybe wrecking yard. But bulb was just 9 buck otb and I rather go new and not have to worry about it for another decade or so.
    eimkeith[OP] likes this.
  10. Nov 18, 2018 at 1:12 PM
    eimkeith
    J Keith
    same here.
  11. Nov 18, 2018 at 1:22 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
  12. Nov 18, 2018 at 6:34 PM
    yotatoy02
    yotatoy02 Well-Known Member
    Will
    1999 Gold Tacoma v6 4wd
    OME 3" Suspension lift, tailgate removal, 2016 wheels
    My truck is a 99 also and was planning on swapping out those led’s
    They’re your normal 74 led correct?
  13. Nov 18, 2018 at 6:43 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Yeah, I got #74 LED bulbs for mine. The heater controls only have 2 bulbs that you can pull out. I used needle nose pliers to pull them, just don't squeeze too hard or you'll break the glass bulb.
    yotatoy02[QUOTED] likes this.
  14. Dec 5, 2022 at 9:30 AM
    texan626
    texan626 Active Member
    Rick
    Waco Texas
    2000 2dr SR5 2.4 automatic
    Trying to figure out what bulb goes in the "low fuel light". 2000 taco dlx plain Jane a/t
  15. Dec 5, 2022 at 12:24 PM
    Skulking
    Skulking Well-Known Member
    San Jose, CA
    1998 Xtra Cab v6 4x4 Manual
    I believe they should be 74's. The important thing though is that the bulb needs to stay incandescent. If you convert it to LED it will always be on.
  16. Dec 5, 2022 at 1:14 PM
    texan626
    Rick
    Waco Texas
    Appreciate you letting me know.
  17. Dec 5, 2022 at 2:39 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Don't forget the cig lighter light. I had to get it from the dealer.
