List of socket sizes found on 1st gen?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pontoon, Feb 15, 2021.
  1. Feb 15, 2021 at 12:00 PM
    pontoon
    pontoon [OP] Well-Known Member
    2000 Tacoma SR5 TRD V6 3.4 5MT
    Hi all,
    I’m in the process of reorganizing my toolbox.
    I've got a complete set of sockets and wrenches.
    I’m actually going to remove some uncommon sizes to make it more efficient for me to work on my vehicles.
    I noticed on a 1st gen Tacoma 99% of the bolts seem to be:
    8, 10, 12, 14, 17, 19, 21, maybe 22?, maybe 24? I read that the axle nut is 35.
    I saw the head bolts are 12 point. I don’t have any 12 point sockets.
    I think that also covers my dirt bike (Husqvarna) and my wife’s CRV except her axle nuts are 32 and 36mm I believe.
    Are there any other sizes on the 1st gen Tacoma? I have a 3.4 if it matters.
    Tdog2.7L likes this.
  2. Feb 15, 2021 at 4:41 PM
    SLAPS 65
    SLAPS 65 Dirty deeds, done dirt cheap..
    Leif
    Nor Cal east Bay Area Ca.
    2000 Tacoma 4wd ex cab 3.4 auto.. manual hub, J shift
    You’re list looks pretty complete to me, don’t think I’ve ever used 22 or 24 on a first gen..
  3. Feb 15, 2021 at 4:46 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  4. Feb 15, 2021 at 4:53 PM
    G-Raw
    G-Raw Member
    99 4runner limited 4wd conversion
    24 for rear diff for sure. 6mm to 24mm will pull apart most Toyota's. Can't comment on axle nut as I'm running manual hubs.
  5. Feb 15, 2021 at 4:55 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Fill/Drain plugs are 24mm for the rear diff and manual trans, and transfer case
    SLAPS 65[QUOTED] likes this.
  6. Feb 15, 2021 at 4:57 PM
    eon_blue
    Azusa, CA
    I've never thought to get specific socket sizes based on the truck...always just went and got a few socket sets so I know I'll have what I need.
    The 35mm is definitely one to buy though for the axle nut. Other than that I think the biggest you'll need is a 24mm
  7. Feb 15, 2021 at 5:05 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    24mm diff and trans drain plugs
    22mm some OE lug nuts
  8. Feb 15, 2021 at 5:35 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    You'll need some bigger wrenches for the tie rod flats. Watch the "Timmy" video and he'll tell what sizes you need. I purchase a cheap set for the job, and ended up having to use a pipe wrench.
    Key-Rei and SLAPS 65 like this.
