Lithium Battery Mounting Locations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jcm, Dec 5, 2022.
  1. Dec 5, 2022 at 2:21 PM
    jcm
    jcm [OP] Well-Known Member
    2017 TRD-OR 6M
    Anyone here using a lithium battery as a house battery? If so, where do you have it mounted? I'm assuming the engine compartment is a bad idea. Anyone fit a 50ah or preferably 100ah battery inside of a double cab without removing a seat? Neither size will fit in the bed cubbies from my measurements unfortunately.
  2. Dec 5, 2022 at 3:15 PM
    GBourne
    GBourne Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
    Not much room under the hood, especially for 100ah, and inside the cab isn’t a horrible idea, but personally I wouldn’t do it.
    I’ll be building a rack in the near future to mount a battery in the bed at the back on the drivers side where the cubby is/should be. It will be a few more weeks until I’m able to get to it though.
    jcm[OP] likes this.
  3. Dec 5, 2022 at 3:20 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I've mounted house batteries in the bed before, but those were AGMs. Do you live somewhere it gets down to freezing or below? If so, in cab is definitely where you want them. Going with self heating battery, or no?
    jcm[OP] likes this.
  4. Dec 5, 2022 at 3:25 PM
    YF_Ryan
    Kent, WA
    jcm[OP] likes this.
  5. Dec 5, 2022 at 3:26 PM
    Firn
    Firn Well-Known Member
    White OR
    If you go with lithium get LFP and not the NMC/lithium-ion technology.
    If it's for running an inverter you can look at batteries that are other than 12 and different form factors since you will be running it through and inverter.
    https://batteryhookup.com/ has very good prices on battery modules if you are handy with electronics.
    jcm[OP] likes this.
  6. Dec 5, 2022 at 3:31 PM
    YF_Ryan
    Kent, WA
    jcm[OP] likes this.
  7. Dec 5, 2022 at 3:59 PM
    jcm
    2017 TRD-OR 6M
    Looking at the Renogy right now, which is not self heating. It lists a minimum storage temp of -13F though, which I've never been in.
  8. Dec 5, 2022 at 3:59 PM
    jcm
    2017 TRD-OR 6M
    YF_Ryan[QUOTED] likes this.
  9. Dec 5, 2022 at 4:02 PM
    YF_Ryan
    Kent, WA
    The bigger thing is the temp at which a lithium can charge. Usually that's only above freezing, >32F. In cab, probably fine, but if it were mounted in the bed I'm sure it could be an issue.
    jcm[QUOTED][OP] likes this.
  10. Dec 5, 2022 at 4:02 PM
    YF_Ryan
    Kent, WA
    What you planning to run off it?
  11. Dec 5, 2022 at 4:04 PM
    jcm
    2017 TRD-OR 6M
    Good point!
    12v fridge, 12v water pump, 12v diesel heater, auxiliary lighting, small inverter to charge laptops.
  12. Dec 5, 2022 at 4:05 PM
    jcm
    2017 TRD-OR 6M
    LFP as in lithium iron phosphate? I plan on it, looking at Renogy currently. I have a few 12v items to power, so plan to stick with 12v at this point.
  13. Dec 5, 2022 at 4:30 PM
    Firn
    White OR
    Lithium Iron, yep.
    Four of these would be 12v
    https://batteryhookup.com/products/new-4-pack-eve-3-2v-75ah-240wh-lifepo4
    Add in a bms.
    https://batteryhookup.com/products/4s-300a-lifepo4-bms-with-balance-12-8v
    That would be 75ah in roughly 10"x6" x8. 5" or double it for 150ah and still be pretty small, plus you have some flexibility in shape.
    Be aware these are pouch cells however and want to be compressed in a case, they need some pressure from the front, back, and sides.
    Something worth remembering is lithium capacity is basically complete capacity and they can be used across their entire operating capacity. Sealed lead acid however have a dramatically shortened lifespan the lower they are drained and a 100ah batter should not be used for more than 50ah if you want it to last, even deep cycle
  14. Dec 5, 2022 at 4:33 PM
    Firn
    White OR
  15. Dec 5, 2022 at 5:06 PM
    jcm
    2017 TRD-OR 6M
    Thanks.
    Yeah, we've killed our fair share of lead acid batteries draining them too far. Looking forward to the 90% drain capabilities of lithium. Plus not needing 150 lbs of batteries to run everything!
  16. Dec 5, 2022 at 5:13 PM
    duckytw
    duckytw Well-Known Member
