Little help please
Discussion in '4 Cylinder' started by Taco02, Jan 4, 2012.
  1. Jan 4, 2012 at 12:43 PM
    Taco02
    Taco02 [OP] Member
    Brad
    Memphis
    02 Tacoma 4x4
    ~Mod-Less~
    Installed a cold air intake on my 02 2.7. There's a vacuum hose that went into the airbox across the radiator shroud into a little piece on the driver fender. I just unhooked it from airbox and left hose open and dangling by windshield washer jug. Now I'm getting a check engine light. What does it do and how can I fix?
  2. Jan 4, 2012 at 12:46 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You need to find a way to hook that hose back up to the vacuum system close to where it originally was.
    What intake was it? Model?
  3. Jan 4, 2012 at 1:06 PM
    Taco02
    Taco02 [OP] Member
    Brad
    Memphis
    02 Tacoma 4x4
    ~Mod-Less~
    Just a homemade one pieced together. Basically a adapter that fits into end of MAF and a cone filter.
  4. Jan 5, 2012 at 10:16 PM
    Taco02
    Taco02 [OP] Member
    Brad
    Memphis
    02 Tacoma 4x4
    ~Mod-Less~
    So no one knows what that hose does?
  5. Jan 6, 2012 at 5:49 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Yes, it supplies vacuum. I'd suggest going back to stock until you get the right CAI or fix the existing one
  6. Jan 6, 2012 at 6:21 PM
    Dustrider
    Dustrider Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    it is the purge for the vapor vent system
    it shouldnt throw a code
    you should buy a simple code reader to find out what the code is. Autozone $60 , also allows you to clear the code
    my bet would be that there is a code for the MAF
    I would just cut my losses and hook it back up to stock intake , there is no advantage to derestricting the stock air filter
