Little help with a blinker LED conversion issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IceMan50, Jan 21, 2015.
  1. Jan 21, 2015 at 11:29 AM
    IceMan50
    IceMan50 [OP] Well-Known Member
    Western MA
    08 Tacoma DBL Cab Long Bed TRD
    TRD Intake
    Let me start off by saying I searched a little and wasn't able find any discussion close to what I'm looking for help with.
    I have an 08 Tacoma and I recently started picking up some LED bulbs for the exterior as well as an LED compatible flasher relay. The first thing I did was swap the front marker/blinker bulbs out (the corners had already been done and have been working for months without issue). I left the stock Toyota relay in place for this part because I figured the rear stock bulbs would add enough resistance to the circuit to allow it to flash properly, plus I wanted to see how they looked before I stated the rears. So with the LED bulbs in place, I went to hit the hazard button on the dash. One quick split second flash and they stopped working. The hazard switch didn't do anything after this.
    Thinking it may be the flasher relay, I took the lower dash apart and got to the relay in back of the fuse block and swapped it out with the LED compatible one. Still the hazard switch didn't work, however now I could hear the clicking in the relay when I used the turn signal switch but no illumination of the exterior lights (LED or stock bulbs, I swapped back just to be sure) or interior dash indicators.
    I went over to AutoZone and grabbed a new flasher relay just incase this was the issue, no dice.
    So what I'm left with is no directionals and not sure what to check next. Is there a fuse for this circuit (I couldn't find one on either of the fuse blocks or in the manual)? Could it be the switch? If so, Toyota wants over $200 for the whole switch and seatbelt indicator assembly. Any input would be greatly appreciated. Thanks
  2. Jan 21, 2015 at 12:37 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Just get a V3 Triton Switchback kit. Problem solved.
  3. Jan 21, 2015 at 12:41 PM
    DrFunker
    DrFunker Well-Known Member
    Jumper may be able to help you with this too.
  4. Jan 21, 2015 at 12:44 PM
    IceMan50
    Western MA
    TRD Intake
    I wanted to do this without resistors because it was cleaner.
  5. Jan 21, 2015 at 12:45 PM
    IceMan50
    Western MA
    TRD Intake
    Nice product but doesn't help me with my present issue lol.
  6. Jan 21, 2015 at 12:47 PM
    IceMan50
    Western MA
    TRD Intake
    Isn't that what an LED compatible flasher relay is for? No hyper flash because it doesn't sense load.
  7. Jan 21, 2015 at 1:58 PM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Good luck with that.
  8. Jan 21, 2015 at 2:09 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    OP, in the engine bay fuse panel. Between radio no.2 and towing. Trn-Haz 15A fuse. Also, if you don't want to add resistors, there are direct replacement LED lights that have resistors incorporated.
  9. Jan 21, 2015 at 5:28 PM
    IceMan50
    Western MA
    TRD Intake
    Windsor, I feel like an idiot that I didn't notice that. You saved my ass. Thanks man, much appreciated.
  10. Jan 21, 2015 at 5:40 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    No prob.
  11. Feb 11, 2015 at 12:45 PM
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    OK, where exactly is the flasher for our Second Gen Tacomas? I just bought one and can't find exactly where it is. Is it a PITA? Don't want to use resistors and I don't have DTRL.
