Little long to crank over...
Discussion in 'Technical Chat' started by mcohn16, Feb 13, 2009.
  1. Feb 13, 2009 at 10:03 PM
    mcohn16
    mcohn16 [OP] Member
    Maryland
    09 Prerunner Dbl. Cab V6 TRD Off-Road
    Anyone else have this problem?
    My truck is only 2 months old and a few times it has taken a bit longer to crank over that a new truck should. Yesterday, it took a suspensful 4-5 seconds before finally catching.
    Should I pay my dealer a visit?
  2. Feb 13, 2009 at 11:18 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Sure, it's still under warranty, let them deal with the problem.
  3. Feb 14, 2009 at 6:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Time it with a stop watch or something. It may seem like 5 or so seconds, when it could actually be around 2 or so. The ECU wont let the engine fire up until a set oil psi is reached. BUT, that being said, if it seems to take longer than normal, it never hurts to have the dealer look at it.
  4. Feb 14, 2009 at 7:02 AM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Try this....I thought I had a problem too. I out the key in the ignition, turn it to on (not start) and give it a second or two. Then crank it over and mine starts right up. This pause happens to me overnight or when it's been 8 hours'ish since I ran it last. If it sits to long there is a fuel system evac that works and knocks the pressure off fuel system. You might hear it every so often if your out by your truck and it's not running. Sounds like a faint hum or buzz. I've ran around swatting imaginary bees thinking there was swarm 'cause of the buzzes. The neighbors keep their distance now.
    In my big truck at work (Kenworth) you have to put the key to on and wait for a few beats and let the 'puter and the ABS run it's checks. If you jump right in and try to crank it over........I'll crank till you kill the batteries.
    I don't know if this is a Toyota thing but in my Yaris, you could turn the key to start and let go of the key, it would snap back to on but the car would keep cranking till it fired off. I thought that was broke too but it's a designed feature.
    000_0033.jpg Precious and Precious II
