Little low on coolant; what should I add
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rmorse, Mar 25, 2019.
  1. Mar 26, 2019 at 6:51 AM
    #41
    rmorse
    rmorse [OP] Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    Owners manuals are consistently wrong; I’m also verifying that I need to purchase the actual Toyota branded fluid. I’m reaching out to Toyota enthusiasts as they know far more than I do.
    Coolant is an area I’m ignorant about and I’m seeking to learn more. I understand that the manual will state to use only Toyota products and services; I’m not bringing my vehicle to the dealer to perform basic tasks like my manual would want.
    jackn7 likes this.
  2. Mar 26, 2019 at 7:51 AM
    #42
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Such as?
  3. Mar 26, 2019 at 8:03 AM
    #43
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    Yeah, in terms of fluids and spec'd parts in owners manuals i have rarely found them incorrect. In fact, i havent personally found them wrong. Its distributed to the masses and everyone gets them. Service manuals, they seem to have issues with torque specs, maybe some wiring.
  4. Mar 26, 2019 at 9:05 AM
    #44
    rmorse
    Bobby
    Bowie, MD
    Consistently wrong is probably a poor choice of words. I meant we consistently find errors in them. For example, “lifetime fluids” in sealed transmissions (I’m coming from the Volvo world, so in particular the AW55 transmissions). The manual clearly states that it’s lifetime and never needs to be changed yet it goes boom if you don’t change the fluid within 75k miles. Or the old school IDI motors having cavitation issues with the coolant they recommended. Or our Tacomas...waiting to change the gear oil at 30k or whatever mileage. You’d be MUCH better served changing it early.
    I’m just saying....sometimes they get it wrong or enthusiasts find better methods. I mean, look at the transmission fluid on the Tacoma’s straight from the factory. Mine was under filled by a solid half a quart. Toyota is saying it’s fine, you shouldn’t need to check your trans fluid until you go to drain and fill at like 60k or whatever miles. Enthusiasts are not only saying that you should check the fluid ASAP, but they’re also saying to drain and fill with a better fluid than OEM.
  5. Mar 26, 2019 at 12:20 PM
    #45
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    That’s good info. I just read the MSDS sheet on all the different ones and came to the same conclusion; they are not the same.
    Norton likes this.
  6. Mar 26, 2019 at 5:24 PM
    #46
    slayer fan
    slayer fan Well-Known Member
    tommy
    ky
    2013 tacoma 4x4 regular cab
    2" lift.
    I use prestone green in all my vehicles, always have and always will. I do, however, drain and refill every other year. no consequences that I've ever experienced.
  7. Mar 26, 2019 at 9:19 PM
    #47
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Good tip bro, thanks!
  8. Mar 26, 2019 at 9:31 PM
    #48
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    As long as it’s not your trans fluid that you drained from trying to do an oil change.
    Trouble_The_Tacoma likes this.
  9. Apr 8, 2019 at 12:44 PM
    #49
    1oldgoat
    1oldgoat Active Member
    '99 Regular Cab 4x4
    Camper top, Custom platform with drawers & trays underneath.
    I thought that 50/50 was supposed to be lemonade and iced tea.....:D
    6 gearT444E likes this.
  10. Apr 8, 2019 at 6:25 PM
    #50
    6 gearT444E
    Deep South
    Herculiner Hootus
    They call that the Arnold Palmer :cheers:
