Little pop when I first start driving
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brawwp, Aug 5, 2022.
  1. Aug 5, 2022 at 7:51 AM
    Brawwp
    Brawwp [OP] Well-Known Member
    Oahu
    2022 white SR 4x4
    I have a new 2022 SR. I get a little pop from what seems like the front end when I first start driving. It happens when it sits a few hours and I leave a parking spot and begin going it’ll pop once and that’s it. Not sure if it’s something I should be worried about or not. Any ideas?
  2. Aug 5, 2022 at 7:53 AM
    HiBillyMaysHere
    HiBillyMaysHere Well-Known Member
    PNW
    2021 TRD Off Road Access Cab
    4cyl or 6?
  3. Aug 5, 2022 at 7:56 AM
    Brawwp
    Oahu
    2022 white SR 4x4
    6 cyl and 4x4
  4. Aug 5, 2022 at 7:57 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Front brake pads shifting, and its normal. Thats my first guess, at least. Dive as far down the "front end click/pop/clunk" rabbit hole you want, but you'll pretty much convince yourself your truck sucks by the end of it (which it doesn't).
  5. Aug 5, 2022 at 7:57 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Brand new truck.. take it to the dealer..
    Big tall dave likes this.
  6. Aug 5, 2022 at 8:01 AM
    HiBillyMaysHere
    PNW
    Put 1,000 miles on it. Follow the break-in procedure in the manual. It's likely parts settling. If it doesn't go away after that, have a dealer take a look just to make you feel better and have any issue on the record.
  7. Aug 5, 2022 at 8:01 AM
    Off Topic Guy
    If not front brake pads shifting, check torque spec for LCA bolts and torque them accordingly. Many alignment shops fail to torque them to the correct amount, and you'll get front end pops alot. Can also look into radiator support/body mount/bushings, but its a long dark hole, and you may never find the actual source, aka its all "normal" if you ask Toyota.
  8. Aug 5, 2022 at 8:04 AM
    Brawwp
    Oahu
    2022 white SR 4x4
    I said new but i have about 1500 on it now I believe
  9. Aug 5, 2022 at 8:06 AM
    xndak
    xndak Well-Known Member
    2023 Off Road
    What flavor and how much pop do you get from the front end?:rolleyes:
  10. Aug 5, 2022 at 10:41 AM
    Macsplace
    Macsplace Active Member
    21 Tacoma
    I had a similar issue when backing out of my driveway and turning. Turned out the bed bolts were loose and when the frame and body flexed ever so slightly it made a noise. Tightened the bed bolts all is good
  11. Aug 5, 2022 at 2:21 PM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    Grease propeller shaft too possibly. I know the manuals clunk a bit too which is unnerving.
  12. Aug 5, 2022 at 2:27 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    If you use your E brake / parking brake, it could possibly be that letting go after you release the handle and begin to drive. I 2nd driving it more before worrying something's actually off.
  13. Aug 5, 2022 at 3:29 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    The front brake pads frequently make kind of a clang noise after the truck sits for a while.
  14. Aug 5, 2022 at 4:06 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    None of the above! It is the computer waking up doing a ABS check. Mine does it too. Nothing to worry about. My truck is almost 4 years old now. Done it since day 1.
    H6G, stftaco, Off Topic Guy and 3 others like this.
  15. Aug 5, 2022 at 4:09 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Pad slap. It is normal. No idea why these trucks do it when every other manufacturer seems to have it addressed, but here we are. Basically, the pads move slightly within the calliper. The combination of brake pressure and rotor rotation ensures the pads stay "up" when you're driving or stopping. If you shift to reverse or park (with no brake pressure) you'll likely hear it again but you'll mostly notice it when you first get in and drive. It's not harmful, just annoying when you're not used to it.
    The previous comment suggested the ABS self check. That is also a possibility. Also harmless, just annoying if you aren't used to it
  16. Aug 5, 2022 at 4:15 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    This is my assumption of the OP's concern as well.
    CusterFan[QUOTED] likes this.
  17. Aug 5, 2022 at 7:35 PM
    Brawwp
    Oahu
    2022 white SR 4x4
    Thanks for all the replies. Seems like nothing to worry about.
    CusterFan likes this.
  18. Aug 5, 2022 at 8:03 PM
    AtomAnt
    AtomAnt Well-Known Member
    Adam
    South Cackalacky
    2019 TRD Sport
    We have a winner. If you pay close attention, you’ll see that it happens at the exact same speed every time. Can’t remember if it’s 3mph or 5mph. Same way the doors lock at a certain speed. Absolutely normal though.
  19. Aug 5, 2022 at 8:32 PM
    MalinoisDad
    Michael
    Can you opt out? :rofl::rofl:
    I’ve been told the ABS on 1st gens wasn’t great. I am greatful mine has none.
  20. Aug 5, 2022 at 9:08 PM
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    I was going to say check your tires for a pebble stuck in the treads which would scratch or pop when starting out but you wouldn't likely hear it once you got moving. However, now I vote for the computer ABS check also.
