Little to no grease in the driveline?
Discussion in '4 Cylinder' started by crashnrondo, Mar 18, 2011.
  1. Apr 6, 2011 at 6:01 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    ^^ thank you ill be doing this very soon... never done it before.
  2. Apr 6, 2011 at 7:01 PM
    Manwithoutaplan
    ID
    take about 5 minutes :)
  3. Apr 7, 2011 at 12:22 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    :eek:
  4. Apr 8, 2011 at 10:16 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    I thought that the U-joints didn't have seals, only dust caps that are meant to allow some grease to be flung out so that new grease can move outward toward the bearings. If there were seals (like the CV joints), there wouldn't be any need for zerks.
  5. Apr 8, 2011 at 10:36 AM
    ecoterragaia
    Central Virginia
    Gotcha, thought you were referring to just the driveshaft. I got scared 'cause I purposely pumped a ton of the old black stuff out of my u joints the first time I did it.
    dust caps = good
    seals = I screwed up
  6. Apr 11, 2011 at 12:02 PM
    Tacoma of Souls
    Tacoma of Souls Member
    Nova Scotia, Canda
    when you grease your u-joints just make sure grease comes out of all the cups. if theres one cup that won't take grease, your u joint will fail some time in the future.
  7. Apr 16, 2011 at 8:11 AM
    JEA86
    JEA86 Well-Known Member
    Jeremy
    WV
    2016 TRD Off-Road
    i just did mine, mine took 4 pumps in each. I have a reg cab i only had 2
  8. Apr 16, 2011 at 8:25 AM
    meeestirg
    meeestirg Well-Known Member
    Vance County, NC
    is there a way to grease it if you don't have zerks?
