Live Clutch Mod (LCM)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Dec 30, 2023.
  1. Feb 23, 2024 at 4:03 PM
    #41
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    I'm a full idiot! :rofl::rofl::rofl: :tinfoilhat:
    I was worried when CC was first brought and am happy there was no functionality change.
    In general for me, LR means it's a good day. :cheers:
  2. Feb 26, 2024 at 7:35 PM
    #42
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Just realized something. The clutch start cancel switch being on allows the tcase to shift into low without pressing the clutch. Never noticed that before. For some reason I was thinking the factory wired the switch in such a way that it would ground out the starter relay when pressed but without also triggering the clutch input for the 4WD ECU for shifting into low. So that was interesting to me to find out.
    I did get my clutch bypass jumper from Dave and it works exactly as intended. I plugged that in and threw it over the kick panel. I just got my new tires and an inspection done so I shouldn’t have to undo any of that for at least a year. Now, to train myself to kick it into neutral and not use the clutch for starts like I did in my Jeep…
    I still want to rewire something into the clutch start cancel switch circuit to turn out that stupid indicator light once the clutch is pressed for the first time. That is how my frontier was, it was perfect. There is no reason for that light to remain on for the entire length of a drive just because you used the button to bypass the clutch on start.
    tonered[OP] likes this.
  3. Feb 26, 2024 at 8:27 PM
    #43
    tonered
    tony
    Lynnwood, WA
    I'm happy for whatever reason that both the CSC and inverter lights are hidden when I am driving. Pretty dumb that the CSC stays lit.
    BLtheP[QUOTED] likes this.
