Live in Colder Climate, still seeing steam after warmup?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WestCoastBestCoast, Dec 27, 2019.
  1. Dec 27, 2019 at 11:33 PM
    WestCoastBestCoast
    WestCoastBestCoast [OP] Well-Known Member
    Wyn
    Portland, OR
    2005 SWB TRD 6MT 4x4
    I’ve noticed that my truck is still putting steam out of the tail pipe well after warmup.
    It hasn’t been getting above 45ish at all recently, but with my old car the steam usually stopped showing after warmup.
    I have an 05, do I have a blown head gasket?
  2. Dec 27, 2019 at 11:35 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Normal condensation being seen
    whatstcp likes this.
  3. Dec 27, 2019 at 11:36 PM
    WestCoastBestCoast
    Wyn
    Portland, OR
    Even all day? Only reason I’m worried is I heard 05s had notoriously bad head gaskets.
  4. Dec 27, 2019 at 11:42 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    The exhaust gasses being much hotter than colder ambient air temperature will produce condensation no matter if the engine is warmed up or not
  5. Dec 27, 2019 at 11:46 PM
    WestCoastBestCoast
    Wyn
    Portland, OR
    Best method to check? Just do a compression test?
    I am just being irrational I hope. I know that if I can see my breath, I should see steam from the tailpipe. I came from a Subaru that I had to have the headgaskets done twice. Just neurotic I guess.
  6. Dec 28, 2019 at 7:04 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    Good on you for paying attention to what seems to be the only real issue with 05-06 trucks, I am the same way with my 05.
    I have encountered several instances where condensation has caused me unnecessary grief because it can look like bad head gasket symptoms. Smell the exhaust. If it's burning coolant, it will smell sweet, hard to miss. I have also had brown water residue inside the oil filler cap that looks exactly like a head gasket leak but was only condensation. A new radiator cap changed the coolant levels in the overflow tank.
    The symptoms of bad head gaskets will not go away, condensation will. Drive the truck for an hour, then check it out.
  7. Dec 28, 2019 at 5:34 PM
    Taco'09
    Taco'09 Well-Known Member
    Mine does it every single day or it drips water depending on ambient temp. And has done so since 2014. I lose no coolant and compression is super.
