Load 2014 Tacoma can carry
Discussion in '2nd Gen. Tacomas (2005-2015)' started by admiral1960, Jan 29, 2019.
  1. Jan 29, 2019 at 9:36 AM
    admiral1960
    admiral1960 [OP] Member
    2014 silver tacoma
    Hi,
    I have a 2014 Tacoma with a 5' bed.
    Will be moving some gravel and am wondering how much weight a Tacoma can handle.
    Thanks for any insights offered !!
  2. Jan 29, 2019 at 9:40 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    About 1200 lbs +/-
  3. Jan 29, 2019 at 10:05 AM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    There was a really good write up on here that someone did about hauling and towing. It was like a bible for Tacoma owners. I cant find it right now so if anyone else has it and can post the link that would be helpful. There's a ton more involved here than just "how much can my truck haul"
  4. Jan 29, 2019 at 10:32 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Not much.
    1,200lbs.
    Get delivery for gravel and rock unless we are talking a very minor amount. Its very easy to go overweight with those materials.
  5. Jan 29, 2019 at 10:38 AM
    pandataco
    pandataco Well-Known Member
    Los Angeles
    2015 DCSB Sport 4x4
    I have loaded my 2015 DCSB Sport several times with 1800+lbs of materials and it always makes me nervous, need to be more detailed when I pick up materials for jobs lol...but everyone always tells me it can carry 2k easy, personally I would never recommend it but that’s just me
  6. Jan 29, 2019 at 11:06 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    A cubic yard of gravel is generally estimated to weigh 2800 pounds. You can decide from there if it's worth it to make multiple trips. Depending on model and options the payload including driver and carried gear is +/- 1200 lbs, (curb weight minus GVWR) its on the door jam sticker. 1200 pounds will put a stock truck effectively on the bump stops.
    PackCon likes this.
  7. Jan 29, 2019 at 11:07 AM
    CHUCK W
    CHUCK W Well-Known Member
    I did this last summer. Gravel is pretty heavy per yard, about 1 ton. I limited my hauling to 1/2 yard of gravel per trip. That's roughly 1,000 lbs.
  8. Jan 29, 2019 at 11:08 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    not effectively... 1200lbs in the bed will SLAM the truck on bumpstops without it even moving. OP rent a trailer and save your truck.
    desertrunner24 likes this.
  9. Jan 29, 2019 at 11:08 AM
    Troyken
    NY
    1/2 yard of gravel is my limit too.
  10. Jan 29, 2019 at 11:15 AM
    Troyken
    NY
    A static load of 1200 pounds (a known volume of water) put my 2+1 off road springs on the stops sitting in the driveway. I have since added a factory 3 leaf pack plus 3 leaf aal. It carries an occasional payload better now
  11. Jan 29, 2019 at 11:21 AM
    AdamM
    AdamM Semi-pro aardvark wrangler
    Adam
    Edmonton, AB
    14 DCSB base 6MT 4x4
    I carried around 12-1300lbs of concrete mix in my bed a few years ago. The truck was an inch or so off the bump stops.
  12. Jan 29, 2019 at 11:23 AM
    Quimby
    Quimby Well-Known Member
    NYC
    2017 TRD OR AC
    I've had a yard of gravel in the back... do not suggest it. It looked like I was doing a wheelie.
  13. Jan 30, 2019 at 7:06 AM
    96carboard
    96carboard Well-Known Member
    When I still had the factory springs, I'd done a few extremely heavy loads. 1/2 yard of limestone screening, AND a trailer that ran about 8000 pounds. That means that I probably had about 2000 pounds extra load on those springs.
    No, it was not on the bump stops.
    But I did eventually break a leaf, but can't say conclusively if the load contributed much to it, since it broke the same as they do for everyone else.
  14. Jan 30, 2019 at 7:09 AM
    96carboard
    Since you have a 5 foot bed, my concern is that the load doesn't balance evenly over the axle as it would on a 6 foot bed. Most of the weight will be behind the axle, which will actually lift up on your front wheels somewhat. This will have negative impact on control.
