load capacity on these tie-down points?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JC0352, Apr 8, 2014.
  1. Apr 9, 2014 at 6:32 AM
    JC0352
    JC0352 [OP] Well-Known Member
    Beau
    NW Louisiana
    '14 DC Off Road 4x4
    I'm at the dealer now, getting perma plate applied. Checked w/ the guy at the parts counter and unfortunately they don't have the d-rings in stock.
    I also asked about the front loops, and he's going to get some info on them from Toyota and let me know. I think it's a red flag when the manual mentions no load rating for them...
  2. Apr 9, 2014 at 7:57 AM
    JC0352
    Beau
    NW Louisiana
    '14 DC Off Road 4x4
    Yea those things will never see a tie-down hook, except maybe for securing camping gear, but not my bike. Oh, and you're user title is hilarious; I love that movie.
  3. Apr 9, 2014 at 10:41 AM
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    I found the below corner supports to be very sturdy and they hold bikes as well. I have one bike on each stock front corner mount as shown here in this thread. And then the second strap for each bike to opposite brackets.
    http://jpmetalfab.com/products.html
  4. Apr 9, 2014 at 11:16 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    If your talking about the effectiveness of an anchor during a crash, then there seems to be a little confusion going on with the strength of any of these anchors. The force from a 200 lb object coming to a stop at 80 mph will be far greater than the rated 440 lbs of a d-ring.
  5. Apr 9, 2014 at 11:52 AM
    JC0352
    Beau
    NW Louisiana
    '14 DC Off Road 4x4
    Honestly I'm just realizing I'd previously only secured the bike for transport, not a crash... Doesn't matter how secure my anchor points were on my GMC; I never secured the back of the bike... Had I hit something head-on, the bike might possibly front-flip out of the truck bed.
    I'm ordering d-rings today from TRDparts4U, and they're going under the bed to frame bolts.
  6. Apr 9, 2014 at 1:53 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    and that means what exactly........?
    When it comes to the safety of myself and others on the road I error on the side of caution. I bought a 800# rated bed rack not because I wanted to haul 800# of wood on my rack - because I wanted the highest rated rack sold for our truck when I haul my (2) 40# kayaks. Do I think a 800# load will remain secured when I crash head on to a brick wall at 80mph...NO. I'm not a retard.
  7. Apr 9, 2014 at 2:21 PM
    moondeath
    Pa, Gardners
    You're getting on people's cases about using an anchor that has a load rating slightly less than a d ring and making it sound like it's going to matter in a crash. Right from your words above. That's misinformation. As a d ring will have a better tie down value, it will not hold an item in a collision.
    It doesn't have to be a brick wall. It can be a collision with a vehicle at a deceleration rate of half a second or at any rate. It's still going to be much greater than the ability of the tie down.
    Force =Mass x Acceleration or Deceleration
    That's all I'm getting at. You're always so angry about everything. Just sit back and drink a beer.
  8. Apr 11, 2014 at 7:41 AM
    JC0352
    Beau
    NW Louisiana
    '14 DC Off Road 4x4
    In case anybody else was wondering, I called Toyota USA's customer service line and they put me in touch w/ a parts specialist. Those tie-down loops are rated for 240 lbs each.
    Regardless, I'm going pick up my d-rings to install under the front bed bolts today.
  9. Apr 11, 2014 at 7:44 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    I got 4 pack of 300lb rated links at Lowe's and some wide fender washers for about $10.
  10. Apr 11, 2014 at 7:53 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    The loops would be a good option to help you with the side to side movement you were concerned with earlier with the straps being nearly vertical. Use the d-rings in the bed bolts to take the brute of the load, and use those loops for a little extra 'anti-tipping' security.
  11. Apr 11, 2014 at 8:00 AM
    JC0352
    Beau
    NW Louisiana
    '14 DC Off Road 4x4
    That's exactly what I was thinking! :thumbsup: Especially when I'm hauling two bikes.
    "Bikes" is pretty general; this thread was started with 450cc 4 stroke mx bikes (< 250 lbs) in mind.
  12. Apr 11, 2014 at 10:37 AM
    ssanders2211
    ssanders2211 Well-Known Member
    Midwest
    '14 DCLB 4x4
    behind the rear seat hi-lift mount bracket, easy-out crossbed toolbox brackets, sliders, ATO plate rear bumper, hood/bed lighting, always-on 12v outlets, dashcam, Viper 5806V w/ GPS
    I spent some time making some brackets and attaching unistrut and cross-bed toolboxes to mine recently, and I'm not so sure they're aluminum. They are extremely rigid for how thin they are and I hit them a bit with a dremel to grind a notch in (so I know where to line up the bracket if it ever gets removed) and it felt like steel, not aluminum. Regardless, I'm with you on not asking more of them than they're rated to handle.
    Disclaimer: I'm not a metalworker or anything. I just like to cut and grind things.
  13. Apr 12, 2014 at 8:37 AM
    JC0352
    Beau
    NW Louisiana
    '14 DC Off Road 4x4
    Does anybody know if the bed bolts are galvanized? I got some rustoleum to coat them after I grind the part that holds the washers on. The can says not to use on galvanized metal...
  14. Apr 12, 2014 at 11:26 AM
    WheelinJ91
    WheelinJ91 Well-Known Member
    Edmonton,AB
    2012 TRD DCSB
    Airaid Intake, MBRP Exhaust, Toytec OME 3" lift w/AAL, Flip-kit, LR UCA's, Weathertech Floor mats, hood and window deflectors.
    when i was able to haul my bike in the box (i have a swing away and tool box now) I DID use these to tie down my Yamaha R6, i never had any problems whatsoever.
    and once tied down if i rocked my bike, it rocked the truck so i feel good about them.
    if you don't trust them, don't use them. trust your own judgement.
  15. Apr 13, 2014 at 1:05 PM
    #35
    TheMuffinMan
    Coeur d'Alene, ID
    Two bikes wrenched down to fuck on the stock mount points since we were going through the mountains and it gets a bit curvy.
    It was also a bit snowy.
  16. Apr 14, 2014 at 7:36 AM
    #36
    JC0352
    Beau
    NW Louisiana
    '14 DC Off Road 4x4
    Where were you heading to? Is that one of the new huskies?
