Load capicity
Discussion in '2nd Gen. Tacomas (2005-2015)' started by magnum922, Oct 6, 2011.
  1. Oct 6, 2011 at 6:36 PM
    magnum922
    magnum922 [OP] Well-Known Member
    2011 DCLB 4.0 tow pkg 4x4
    A courier where i work has a 2005 tacoma 2wd regular cab 4cyl and says his load capacity is 2000 pounds total. I didnt think this is right since my double cab lb 6cyl 4wd has a 1100 pund capacity. What is the load capacity for the reg cab 2wd 4cyl?
  2. Oct 6, 2011 at 6:38 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Just whip 'em out, measure and be done with it...
  3. Oct 6, 2011 at 6:39 PM
    saugus
    saugus Well-Known Member
    2k is 1 ton. He may lift it but it aint legal. Unless he has upgrades.;)
  4. Oct 6, 2011 at 6:40 PM
    Brunes
    Brunes abides.
    Rotorhead
    Your courier friend is an idiot (or I can't read). The highest total cargo capacity I see is 1300#. He'd be in that range.
    Your truck weighs more stock-4x4,V6, More cab, etc...so your capacity is less by a couple 100#'s
  5. Oct 6, 2011 at 6:42 PM
    saugus
    Reminds me of renting the Lowes truck the other day. It says no more than 1500 lbs load. The employee with the fork lift insisted that the 2700 lb pallet would be o.k. even after I mentioned the limit, so I said "great":D Low rider all the way home (1 mile):cool:
  6. Oct 6, 2011 at 8:31 PM
    Goober
    Goober Earthlings are fun to watch!
    Utah - Why just have only one?
    '11 TRD Off-Planet AccessCab
    From the 2005 Brochure
    • 2005.pdf
      File size:
      912.2 KB
      148
  7. Oct 7, 2011 at 11:13 AM
    magnum922
    I thought 2000 pounds didnt sound right. He also said he put 2400 pounds once and the ass was dragging but did it.
  8. Oct 7, 2011 at 11:26 AM
    ouyin2000
    ouyin2000 Well-Known Member
    Arlington, Virginia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    There's also something called a safety margin. Of course it will do it, but not safely.
  9. Oct 7, 2011 at 1:00 PM
    Pugga
    Massachusetts
    F-150 Mod
    Just because it worked doesn't mean it was a good idea...
  10. Oct 7, 2011 at 7:06 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    The rental trucks from Home Depot and Lowes are 2500 or 3500 HD trucks...they can handle WAY more than 1500 lbs. I wouldn't hesitate to put 1500 lbs. in my 5 lug (and I have in the past).
    I think Toyota says the payload is 1350 for my truck.
  11. Oct 8, 2011 at 7:56 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    My DC/SB/4x4/auto is rated to carry 1360 lbs (remember that includes driver, passengers, tools and tank of fuel). With the spring TSB in it handled 3/4 ton of gravel very well this summer; never bottoming and well controlled. BUT, I'm aware the truck's not rated for it.
    So...no doubt your friend's handled his load. But in addition to not being safe because suspension's overloaded (especially if his doesn't have the TSB springs/shocks) it wears axle bearings super fast and could break springs. Just don't do such craziness very often if we value our trucks.
    Oh yes... and I hope he ran tire pressure to max pressure on the sidewalls? The max pressure gives the maximum load handling capability. Probably the most dangerous thing is tires under inflated for the load.
  12. Oct 9, 2011 at 10:06 AM
    Goober
    Back in '73 I had a 1/2 ton GMC that the axle housing had been bent and axle broken due to an overload and hitting a pot hole. To get the axle out the housing ends were chained to the floor and the center jacked up.
