load index,,,and max load
Discussion in 'Wheels & Tires' started by linkfeeney, Dec 22, 2008.
  1. Dec 22, 2008 at 1:11 PM
    linkfeeney
    linkfeeney [OP] Well-Known Member
    link the stink!
    aberdeen, nj
    09 Doublecab TRD Off-Road! Magnetic Grey!
    what is the load index?
    also if the tire max weight is less than my truck...like the BFG rugges trail handles like 2200lbs.. but our truck is heavy than that
    but since the truck has all the tires, does it mean the weight will be distribute it to all 4?
    I saw the toyo open country.. they have the same tire but all different weight and load index.
    some says max weight is 3000 and some at 3400
    anyone can help me? :)
  2. Dec 22, 2008 at 3:12 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Why are ya worrying about it? .....as long as you're getting 'LT' (light truck) tires, you shouldn't have to worry.
    Our trucks with the amount they actually weight and the towing capacity - it's a drop in the bucket.
    But if you're getting technical...not only do you take the tires into consideration, but wheel size/width, tire pressure, tonque weight, load, etc etc etc.
  3. Dec 22, 2008 at 6:50 PM
    linkfeeney
    link the stink!
    aberdeen, nj
    they have different prices on the same size tire...
    I guess I'll just get the lower load index, since it is cheaper
  4. Dec 22, 2008 at 6:55 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    You don't even need LT tires. I have performance tires on mine & tow an 18' bass boat. Never have any problems. I would worry about loads, unless you are dealing with excessive loads.
