Load leveling air bags for '12 AC 4X4 V-6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by helibear, Jan 13, 2012.
  1. Jan 13, 2012 at 12:49 PM
    helibear
    helibear [OP] Member
    Greg
    Indiana
    2012 Tacoma Access Cab 4X4 V6
    I am thinking about putting load leveling airbags on my '12 access cab 4X4 V-6 to help out when pulling my 25' pontoon boat. What is the best manufacturer and source for a no-drill, bolt on install of a quality product? I am leaning toward not installing a compressor since I pull the boat only occasionally
  2. Jan 13, 2012 at 12:56 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    firestone rite ride air bags FTW. I keep a simple bike pump in the truck, it takes about 5-10 pumps to go from 10psi up to 40psi. i posted a link here somewhere think it was sdtrucksprings.com. they are $259 with free shipping. much cheaper than anywhere else. took about 3 hours to install. no drilling no cutting
    here ya go...http://www.sdtrucksprings.com/firestone-2407-ride-rite-air-bag-kit-toyota-tacoma-4wd-2005-2011
    i got them this summer for $259 but they have them listed for $289 now.
    you can also look into "Air Lift" brand, they are $40-60 cheaper but just dont look as tough and i have not seen any reviews
  3. Jan 13, 2012 at 2:14 PM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    +1 Firestone ride rite air bags
  4. Jan 13, 2012 at 2:23 PM
    Adam Baum
    Adam Baum Well-Known Member
    PCS
    01 PreRunner SR5 debadged
    Amazon may have it cheaper. I bought mine this morning for $270 w/ free shipping. I have a first gen but it is worth looking into.
  5. Jan 13, 2012 at 2:34 PM
    SplitDecision
    SplitDecision Phones Ringin Dude
    Haywood Jablowme
    NY
    Silver TRD OR
    Bilstein 5100x4, Truxedo lo pro QT,Hid Retro,2011 painted grill,Alpine head unit,Foglight mod,NFAB steps
    Very happy with my Firestone bags.
  6. Jan 13, 2012 at 10:16 PM
    black cx
    black cx Well-Known Member
    Bay Area, CA
    2010 Tacoma 4x4
    is it recommended to add another leaf with the airbags?
  7. Jan 13, 2012 at 10:26 PM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    I also like my Firestone bags. The other brand (Can't remember which) requires drilling I believe.
    I just posted this in the other thread in fact:
  8. May 28, 2012 at 6:27 PM
    Equara11
    Equara11 Member
    San Jose, Ca.
    '11 4x4 Dbl. Cab V6
    OME 885x front coils with OME shocks, Driver side coil Trim Packer, 10mm top plate spacers, Light Racing UCA's, 1 inch differential drop, swaybar relocate hardware, carrier bearing drop, rear Bilstein 5100 shocks with 1.5 inch block, Firestone Ride Rite Air Bags, front windows tinted.
    My 2011 double cab TRD Off Road is running 1 inch blocks with the stock rear springs and OME shocks. I prefer not to remove the blocks. Does anyone know if the Firestone air bags will fit with my current set-up?
  9. Jul 8, 2012 at 5:30 PM
    tyaker
    tyaker Well-Known Member
    Southern Oregon
    '11 4x4 DCLB TRD Sport
    Leveled, Dakar HD rear leafs, Ride-Rites
    Bump for ^^^
    I've got 2" rear blocks on the 2011 DCLB TRD 4x4 I just bought. Gonna slap some Firestone bags on the rear for hauling/towing. I want to know if there's enough room for the bags, too.
    Equara11, lemme know if you find out anything.
  10. Jul 8, 2012 at 6:03 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    You guys should be OK to install them with stock springs and lift blocks since the distance from the frame to the center of the spring has not changed. The only concern I'd have is that the shocks do not extend more than factory, as in, 2" block should have a 2" longer shock (fully extended compared to stock fully extended). The shocks are what prevent over-extension and damage to the bags.
  11. Jul 9, 2012 at 7:43 PM
    tyaker
    Southern Oregon
    :thumbsup: Thanks, landphil. The stock TRD Bilsteins do look a little extended. I"ll probably get a set of 5100's for the rear to make sure I'm not pullin' things apart over time.
  12. Jul 13, 2012 at 6:39 PM
    Equara11
    Equara11 Member
    San Jose, Ca.
    '11 4x4 Dbl. Cab V6
    Sorry for the delayed response to your question. Anyhow, I installed the Firestones last weekend and I am more than pleased with the outcome. The truck rides great and is more stable than I imagined it would be. Rough/bouncy type of ride though at times inflated to 15 lbs. You want to maintain at least 5lbs of air in the bags, as they will act as your new bump jousts. So, I will incrementally decrease to 12, 10, and so on....just to see how it rides and to keep the slight lift.
    As landphil said, you will not have a problem with the install based on the center of the springs and the frame distance always being constant. The bolts that accompany the kit are long enough to install on a leaf pack of 4.
    FYI - It took longer than I planned to install, so plan on more than half a day if you will be flying solo. Hope this helps.
  13. Jul 14, 2012 at 8:15 AM
    tyaker
    Southern Oregon
    Thanks for the info, Equara. I'll be doing my install in a week or two. You firmed up my choice to go with the Firestones. Good to know about figuring out the best pressure to ride with, I'm mostly going to be using them as a booster for towing/hauling. Just curious, you mentioned some extra lift. How much height did you gain at the highest pressure you filled?
  14. Jul 15, 2012 at 4:02 PM
    Equara11
    Equara11 Member
    San Jose, Ca.
    '11 4x4 Dbl. Cab V6
    Tyaker - The Firestones will perform great for towing/hauling. Pretty much the main reason I bought and installed them.
    The rear of the truck raised about 3/4 of an inch at 15 lbs. (Total of 3 inch rear lift on my truck) Unfortunately, I am noticing a very slight take off shudder a this height. Nothing serious, though.........
    Good luck with the install.
  15. Jul 15, 2012 at 6:19 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Yeah the ride rites for the 4x4 are a pain in the ass to install. You need small kid hands. The ones for the 2x4 are way easier to install.
    But they work great.
  16. Jul 16, 2012 at 7:19 AM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Maybe you guys did, but dropping the spare tire helps a lot when installing.
  17. Jul 16, 2012 at 9:46 AM
    BlackSeven
    BlackSeven Well-Known Member
    Maryland
    2017 4cyl 5 spd 4x4 extended cab
    Toytec Ultimate Lift kit, Toytec Rear AAL, 4.88 Gears, ARB Rear locker, Doug Thorley header, Volant Cold Air Intake, Demello Offroad front high clearance bumper, ARB On board Air compressor, BLHM, Wet Okoles, 2011 Color matched grill, Weathertech mats, 4x Innovations Sliders, ATO Engine Skid plate, ATO High lift bed mounts.
    I have had the Airlift bags on my frontier before, the ones you need to drill through the frame, and while they were better then no airbags at all - quality wise the riderites are WAY better engineered (no drilling), and the rubber bags are also much thicker and higher quality.
  18. Jul 16, 2012 at 2:17 PM
    Kelly's
    Kelly's Well-Known Member
    N.H.
    '21 DCLB Limited 4x4
    does anyone feel the firestone air bags help with taco lean? I'm getting rid of my 10 and picking up 12 sport dcsb thinking of putting these in.
  19. Jul 16, 2012 at 8:42 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Personally I've never noticed the infamous "Taco Lean", until recently it never got parked on a flat surface, so that might be part of the reason.
    That said, there are two ways you can plumb the air lines. The kit comes with two separate schrader valves to allow setting the pressures individually, so you could put a few more psi in one side if you wanted, which should correct lean. Optional is to tee the bags together so both get equal pressure, and would have no effect on lean. The tee is not inluded in the kit.
  20. Jul 16, 2012 at 9:00 PM
    tyaker
    Southern Oregon
    Did you say you tee-bagged your Taco? :D
