Load Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacoboy69, Jul 16, 2018.
  1. Jul 16, 2018 at 10:50 AM
    tacoboy69
    tacoboy69 [OP] Well-Known Member
    If something has a load capacity of 300 pounds, can you over tighten a ratchet strap and exceed that amount of force? If something weighed 250, would you need to factor the pressure and tightness of your tie down into that capacity? Just curious, don't want to overtighten and bust a bed cleat.
  2. Jul 16, 2018 at 11:01 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The my factory cleats tie into the frame. Ive put real pressure on the cleat and not close to pulling one out. If you are worried add more cleats, there is a “Mod” for this.
  3. Jul 16, 2018 at 11:03 AM
    myrr
    myrr Well-Known Member
    PNW
    2024 TH Allocated
    The weight of what you are tying down as it relates to the ratchet strap would only factor in if you were suspending it. Otherwise you are talking about separate forces.
  4. Jul 16, 2018 at 11:07 AM
    Clearwater Bill
    Billy
    Largo Florida
    Cleats is the term typically used for the movable ones that are in the bed rails.
    D Rings are what the ones that are in the bed floor are called.
    I suspect you are speaking of D rings?
    You can also put a fairly reasonable load on the bed rails and handle lots of every day stuff. Just no where near what the D rings will hold.
  5. Jul 16, 2018 at 11:23 AM
    phsycle
    phsycle Well-Known Member
    CA
    tonered and Joe23 like this.
  6. Jul 16, 2018 at 11:24 AM
    tacoboy69
    Basically just wondering if overtightening straps can damage the rail cleats, I guess.
  7. Jul 16, 2018 at 11:28 AM
    myrr
    PNW
    2024 TH Allocated
    I doubt you would be able to damage the cleats within the limits of the straps / buckles themselves. I would spread the load across 4 cleats instead of just 2, if you are really strapping something in there that tight........
  8. Jul 16, 2018 at 11:29 AM
    rnish
    Tacoma 2nd gen
    OK, fair enough. I have put mucho pressure on the bed d-rings. I really don’t use the cleats for anything more than to bungee a gas can in the bed.
  9. Jul 16, 2018 at 11:37 AM
    Clearwater Bill
    Billy
    Largo Florida
    You can easily put enough pressure on a cleat to collapse a bicycle front suspension with no issue.
    Just have to give a bit of thought to what you are using them for.
  10. Jul 16, 2018 at 11:39 AM
    tacoboy69
    Basically I was moving a queen mattress & box spring and my ratchets were too short to reach D rings so I used front cleats and the metal hooks the tailgate connects to. I wasn't sure how tight I needed to strap them down and didn't want to force it and break something. New to truck world.
  11. Jul 16, 2018 at 12:00 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Here ya go man. If you need help just ask! https://www.engineeringtoolbox.com/levers-d_1304.html
  12. Jul 16, 2018 at 12:09 PM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    If it were me, and to feel at ease on highway.
    I'd bring whatever load you are attaching to this device to 50-60% of the capacity it can handle. Then the remaining 50-40% can be for external forces, such as wind or items moving around.
    Remember even if a rack has a capacity of 300 lb carrying capicity, its only as "secure" and safe as the capacity of the attachment points, d-rings, bolts, or rivots, etc.
  13. Jul 16, 2018 at 1:03 PM
    phsycle
    CA
    I don't know. You can crank on those ratcheting straps pretty hard.
    tacoguy88 likes this.
