Load Range: C, D, E or P-metric?
Discussion in 'Wheels & Tires' started by BryWi, Feb 17, 2011.
  1. Feb 17, 2011 at 11:00 AM
    BryWi
    BryWi [OP] Psalm 109:8
    Earth
    2011 TRD off-road DC SB w/JBL
    5100s, black valance
    Looking for opinions on different load ranges and how they compare.
    I do mostly highway driving, but may find the need to do some mild off-roading in the future.
    Would a C load range be a reasonable alternative to D or E, with better ride quality?
    Or would it be more like a P-metric with a little heavier side wall?
    Or somewhere else in between?
    I'm a real newb when it comes to tires, and only know what I have read on TW. I didn't see this particular comparison on any other threads.
    Thanks in advance for any info...
  2. Feb 17, 2011 at 11:06 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I don't think you can even buy load range "C" light truck tires anymore - they've all gone D and E.
    Tacomas can't carry enough weight to justify an LT tire on load alone. However, an LT tire, with its thicker casing and increased number of sidewall plies is more durable off road, and less likely to suffer cuts and punctures.
    The downside is the (considerably) increased weight and rolling resistance makes for a less comfortable ride and increased gas mileage.
    My Goodyear MTR/Kevlar LT285/70R17 Load Range D tires weigh roughly twice as much as the Dunlop A20 P245/75R16 tires they replaced. Granted they're also larger, but a P tire in that size would have about split the difference.
    Short answer: If you're not going off road - stick to the P-Metric tires.
  3. Feb 17, 2011 at 11:14 AM
    BryWi
    Earth
    I was looking at Geolandar A/T-S in D but read some opinions about the ride stiffening up. And before anyone flames me, I know it's a truck. Just trying to strike a balance between necessary utility and comfort.
    The Falken High Country comes in LT in C range. Only weighs 49 pounds. That's in the running as well.
    It also comes in P-metric..
  4. Feb 17, 2011 at 11:15 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    OK, If the tires I wanted were available in LT load range C, that's probably what I'd get.
    If you're offroading a lot, you need to be carrying both a spare, and a tire repair kit with air compressor anyway.
  5. Feb 17, 2011 at 11:17 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    If you're overloading your truck (e.g. double cab with pop-up camper and gear) - step up to load range D.
  6. Feb 17, 2011 at 11:18 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Agreed
  7. Feb 17, 2011 at 11:19 AM
    BryWi
    Earth
    Going back to what you said before, the LT and C combo is not common. I've been looking at tires online for two frickin' months and I still can't make up my mind. :rolleyes:
    But I definitely would like to hedge my bets and have a tire capable of going off-road if needed.
    Thanks for your input...
  8. Feb 17, 2011 at 11:23 AM
    BryWi
    Earth
    You never know, but I don't anticipate it being a payload issue. More of medium trail-type stuff with smaller rocks and tree roots. Wooded areas, gravel roads, etc.
  9. Feb 17, 2011 at 11:49 AM
    tuckr2
    tuckr2 Well-Known Member
    Western Washington State
    2010 Silver dbl cab LB 4x4 It's Purdy too!
    LT265/70/17 BFG A/T's, Disabled Seat Belt Buzzer, Black and Gray Covercraft Seat Covers front and rear, Matching SnugTop Supersport Canopy, undercoat, bed mat, window vent shades. Black Weathertech Liners. Trans TSB, Rear Spring TSB Installed.
    Unless your planning on pulling a fairly heavy trailer or something, P metric is what comes on the truck and more than suitable for almost all applications.
    Load range D, E, will affect ride (stiffer), and usually gas mileage (heavier).
  10. Feb 17, 2011 at 12:07 PM
    OZ-T
    Peter North
    British Columbia
    Check out the Hankook AT's , lots of guys on here are happy with them .
  11. Feb 17, 2011 at 12:23 PM
    tuckr2
    Yokohama Geolander A/T-S is a great all around highway, light off road tire that would probably meet your needs. Reasonably priced too.
  12. Feb 17, 2011 at 12:27 PM
    trdr6
    trdr6 Well-Known Member
    Clay
    Greensboro, NC
    '10 TRD Off-Road 4X4 Double Cab Magnetic Grey
    AFE Stage II Si CAI, Raptor Series Straight Chrome Step Bars
    I'll be replacing mine with C's or at the most D's. E's are just more than I'll ever need but I hate the way my stock's (P metric) look slack when properly inflated. I'll probably go with Duratracks, you have to look but I've seen them available in C load range.
  13. Feb 17, 2011 at 12:28 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    I have Firestone Destination A/Ts in load range C I picked them because of the extra ply and higher pressure capacity.
    I got into an argument once about how C rated tires are useless cause the weight rating on them is less than a P rated tires. BUT LT tires are derated because tire companies expect them the be loaded so they underrate them a little but where as P rated tires the max weight rating is all you got.
  14. Feb 17, 2011 at 1:06 PM
    BryWi
    Earth
    I've read good reviews on them as well, but I like the tread on the Geos and High Countrys better. I also prefer a simple design on the side wall. The hankooks got a little more going on than I prefer.
    But it's down to those three considering all factors (ride, some off-road ability and appearance).
    Thank you to everyone for the input.
  15. Feb 18, 2011 at 12:56 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    There is absolutely no need to step up to a D load tire for hauling a camper and gear on a Tacoma.
    Say for instance you are looking at a 265/75/16 tire, randomly chose a Goodyear Duratrac Load C range has a load index of 112, which is about 2,400 and something pounds PER tire. Multiply that by 4 = 9,600 lbs...basically a Load C is even more than our little Tacomas can handle.
  16. Feb 18, 2011 at 2:42 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    I have P rated all terrain tires, mostly highway and some minor offroading, they have held up just fine for 2+yrs.
    My gas mileage was not affected and my ride quality improved over the sloppy dunlops I had.
    I'd never go with D or E rated tires on a Tacoma. We have E rated on our Chevy 2500HD that we use for towing over 10K pounds and the ride quailty and gas mileage sucks, D rating would be just as bad.
    LT or C rated tires and also P rated all terrains are sufficient.
  17. Feb 18, 2011 at 3:01 AM
    chilean101
    chilean101 Active Member
    ives
    ventura
    09 off road debadged
    Grillcraft mesh grill (top and bottom), Aries bullguard, shorty antenna, debadged, k/n cold air intake and air filter, 33 in bridgestone duelers a/t ,tinted windows all around, ddm 4500 lo/hi hid kit, webasto retractable moonroof, custom trd decals(scokmonkey), 3 inch revtek lift kit, led map and dome lights. super white fogs, newly added toyota OEM roof rack ,n-fab stainless steel side steps, chopped exhaust, full size trd anthracite spare tire . modded bike rack and spare tire rack mount(made by snobord 552)
    I've had bfg all terrains on my last Tacoma load range d ,even though they looked good they rode like shit (like a tractor), I then got passenger rated Michelin and it was way to soft a ride. Once I got my new truck I slapped on bridgestone duelers a/t load range c and they're great , Not too rough or too soft
    C is the way to go
  18. Feb 18, 2011 at 8:33 AM
    BryWi
    Earth
    With the research I have done, that was kind of my conclusion as well. I just wanted to throw it out to confirm, and get some opinions from owners like yourself that have actually had the different load ranges.
    Got a lot of great opinions depending on my specific use.
    Thanks
  19. Feb 18, 2011 at 6:09 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    The stock TRD BFG Rugged Trails in 265/70R-16 are light (30 lb) quiet on the highway, and stable at high speeds. I've taken them to over 100 mph (uh, on a privately owned closed road course... :cool:) and the truck behaves better than my previous sedan. The total weight of a Rugged Trail tire together with a Konig Countersteer (18 lb) is lighter than a BFG All-Terrain tire alone. Something to think about if you don't plan on serious off roading.
  20. Feb 18, 2011 at 8:32 PM
    vermintrex
    vermintrex Well-Known Member
    Vancouver
    TRD SPORT Shorty
    BFG A/T KO 265/70/17, '11 FJ wheels, 5100's all four corners, Eibach springs, 1/4" Taco lean spacer, Leer 100XR, WeatherTech liners, trimmed mud flaps and I farted in it.
    My BFG A/T 265/70/17's are C rated. Just got 'em last year, don't think they're uncommon.
    Ride great.
