Load Range "C" (OR Close) off-road tire options..?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GeneC, Jan 19, 2016.
  1. Jan 23, 2016 at 3:23 PM
    #41
    Metalnut
    Metalnut It's a clown world
    Adam
    North Alabama
    2016 Tacoma DCLB 4x4 TRD OR
    BP-51s, UCAs, BAMF sliders, SCS Stealth 6, 285 Wildpeaks, HIDs, LEDs, custom grille, hard top.
    I can't get over 19mpg even on the highway with a bone stock truck with stock Goodyear tires :-\ But I do live in the mountains, so I'm assuming that tons of gradual uphills can do that.
    Since I wanted the (17") SCS Stealth 6 wheels, I was able to get the 265 KO2s in C ratings. They're sitting my garage, gorgeous tires. I'm just waiting on the wheels now.
  2. Jan 23, 2016 at 4:45 PM
    #42
    gsxxr
    gsxxr Well-Known Member
    2016 tacoma trd sport
    3" lift, goodyear wrangler duratracs 285/70r17, k&n filter, bakflip vp tonneau and tint.
    I love my goodyear wrangler duratracs.
  3. Jan 23, 2016 at 4:51 PM
    #43
    Metalnut
    Adam
    North Alabama
    No, that's what I meant by bone stock truck. I do have a tonneau cover, though. I don't know if the fuel around here is winterized in any way, but clearly I'm not getting the 20+ mpg people are reporting. And I've been running on premium fuel since new too (yeah, I know, let's not debate).
  4. Jan 23, 2016 at 7:39 PM
    #44
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    I've found all my vehicles whether bone stock or modified miss the MPG numbers a bit. I think that's partially due to our gas blend.
    Our gas companies here (Canada) are required to use up 10% ethanol in the mix- or more.... total BS though because they alway max it out . Sometimes more based on some threads I've read that have sent some away to test.
    Not sure what refineries /govt regulations are required to do there?
  5. Jan 23, 2016 at 7:45 PM
    #45
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Shell 91 is ethanol free in Canada
    BMWags likes this.
  6. Jan 23, 2016 at 7:45 PM
    #46
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    bumping up to a 265/75r16 will actually make your speedo more accurate as it reads high, stock.
    So not only does the 3.4% increase in tire diameter make your speedo more accurate, it also means that when your truck has taken you 100,000 miles, the odometer will read 100,000 rather than 103,400 miles. (I know - who gives a shit, right? well... lease companies probably do.)
    genghis_khan likes this.
  7. Jan 23, 2016 at 7:57 PM
    #47
    YotaLife406
    YotaLife406 Well-Known Member
    16 DCSB OR M/T
    What about the Falken AT 2??? Does anyone have any experience with Falken??? I've read and seen that some serious off road racers like them.
  8. Jan 23, 2016 at 8:04 PM
    #48
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    +1. Not a "C" load tire but performs better than the Duractrac's according to TW members who have driven both. Loving my set in 265/75/16. A great year-round tire for driving in VT.
    spinglow[QUOTED] likes this.
  9. Jan 23, 2016 at 8:06 PM
    #49
    Metalnut
    Adam
    North Alabama
    Good points about the Ethanol in gas, we're dealing with 10% at all pumps (if you believe the numbers posted). That could definitely have something to do with it.
    In the end I don't care THAT much, gas is cheap(er) these days and I choose to pay more for Premium anyway. I only use the Tacoma for commuting when the roads around me are frozen, otherwise I commute by motorcycle and I'm getting about 42 mpg with that.
  10. Jan 23, 2016 at 8:08 PM
    #50
    Metalnut
    Adam
    North Alabama
    I've read a TON of reviews and threads about the DuraTrac and AT/3 tires, I feel like there are plenty of success stories for both. Not being able to decide, I went with KO2s :p But honestly it was the snowflake rating of the KO2s as well as the reported wet road and highway compliance that swayed me.
    For what it's worth, someone on this forum posted about having mounted/balanced hundreds of these tires and stated that DuraTracs always needed a ton of lead weights. Apparently the KO2s hardly need any. I don't think that says anything specific about the performance, just a small data point.
    .45 JHP and stealthmode like this.
  11. Jan 23, 2016 at 8:20 PM
    #51
    stealthmode
    Alberta
    Hmm gonna have to try that for a couple tanks.
    .70 right now here in Alberta for regular @ the moment. Cheaper at the no namers
  12. Jan 23, 2016 at 8:24 PM
    #52
    MadRiverTaco
    Brenden
    Waterbury, VT
    Right on Adam. The more you search on here, the more you find that there are 4 or 5 tires that are frequently recommended for their proven track records. It's personal preference at the end of the day, and the tires have to meet YOUR needs and lifestyle. Luckily TW puts you in touch with others who have similar lifestyles to make the decision a little easier. :cheers:
  13. Jan 23, 2016 at 8:26 PM
    #53
    OZ-T
    Peter North
    British Columbia
    Yeah , Shell V Power 91 is ethanol free and I think Petro Canada has an ethanol free
  14. Jan 23, 2016 at 8:29 PM
    #54
    YotaLife406
    16 DCSB OR M/T
  15. Jan 23, 2016 at 10:41 PM
    #55
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    I won't go with a 265/70 17 inch rims because I want to stay stock size and not muck with Speedo or fuel economy. I'm fine with 17" rims but then you need a C rated tire in 265/65 to wrap them and remain stock size
  16. Jan 24, 2016 at 12:55 AM
    #56
    OZ-T
    Peter North
    British Columbia
    The speedo / odo is already wrong
    JimboAnz likes this.
  17. Jan 24, 2016 at 4:22 AM
    #57
    GeneC
    GeneC [OP] Well-Known Member
    Maine
    2016 TRD OR Access cab
    Hi neverstuck.
    Not doubting your info (well, i guess , I am..;).). Your saying that the STOCK speedo if not accurate.? Why, in heck, would Toyota do that? Could you send links to info. I would be interested in finding out more.
    Thanks.
  18. Jan 24, 2016 at 4:23 AM
    #58
    GeneC
    Maine
  19. Jan 24, 2016 at 10:04 AM
    #59
    redneck pilot
    redneck pilot Well-Known Member
    North Texas
    2023 SR TSS Off-Road 4x4
    I ran the Falken AT's on a Jeep before. They would not balance. I'll never buy one of their tires again.
    spinglow likes this.
  20. Jan 27, 2016 at 9:01 AM
    #60
    eternus
    eternus Well-Known Member
    Longmont, CO
    2009 MGM DCSB TRD OffRoad
