Load Range E instead of C?
Discussion in 'Wheels & Tires' started by 709GADE, Jul 24, 2015.
  1. Jul 24, 2015 at 2:02 PM
    Dilleytech
    Dilleytech Well-Known Member
    Jakob
    White salmon, Washington
    07 AC SR5 4x4
    Front ARB bumper, LR UCA's, OME 885/90021 struts, Ome shocks rear, general springs HD leaf pack.
    My buddies truck on 35's claims he gets 21 mpg. That's about 3 better then me and his tires are 4 inches taller..
  2. Jul 24, 2015 at 2:03 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    You're not d
    You arent doing it right, larger tires make you lose MPG.. thats a fact.
  3. Jul 24, 2015 at 2:05 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I swapped to 17 TRD wheels just for that purpose. The KO2s are 8lbs lighter than the same size 265/75/16s.
  4. Jul 24, 2015 at 2:08 PM
    Dilleytech
    Jakob
    07 AC SR5 4x4
    But how much heavier are the rims? Might equall out about the same maybe.
  5. Jul 24, 2015 at 2:10 PM
    Pigpen
    Dan
    Northwest Montana
    I'm done with this pissing match. I can do math. YMMV
  6. Jul 24, 2015 at 2:18 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Depends on the wheel you are starting with.
    Toyota went through great lengths to make the wheel/tire setup on the TRD off-road very light. The SR5 and Sport wheels are heavier than the off-road TRD wheels, so you could even save weight on the wheel in addition to the tires if you are starting with one of those. The 16" TRD off-roads weight 23lbs. You can get the 17" TRD Pro wheels for $161 that weigh 25lbs. So the net savings would be 6lbs per corner if you have TRD off-road wheels.
    I did a writeup on wheel tire options for that size to keep weight to a minimum here:
    https://www.tacomaworld.com/threads...ior-beadlock-style-wheels-on-a-tacoma.381030/
    Edit: Here is the cheapest I have seen the 25lb 17" Pro wheels:
    https://parts.olathetoyota.com/ppc.html?searchText=PTR20-35110-BK
    Dilleytech[QUOTED] likes this.
  7. Jul 24, 2015 at 2:23 PM
    Dilleytech
    Jakob
    07 AC SR5 4x4
    Great info thanks!
  8. Jul 24, 2015 at 2:43 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I did some wheel weight research before purchasing. I knew the TRD OR were about 22-23lbs so I wanted to stay at or lighter as A/T tires are heavier. Settled with MK6 at 22lbs.
    FYI, stock BFG rugged trails in 265/70r16's are 38lbs.
  9. Jul 24, 2015 at 2:49 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yep, and a 265/75R16 KO2 weighs 53lbs. That is a crazy 15lb increase over stock!
    Hence the importance of trying to keep the weight gain to a minimum.
  10. Jul 24, 2015 at 2:51 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I was looking at the KO2's as they look good in person and wanted to give them a try but they only come in Load E so they were out.
  11. Jul 24, 2015 at 2:51 PM
    Dilleytech
    Jakob
    07 AC SR5 4x4
    Do you know what the 16" 2007 sr5 wheel wieght?
  12. Jul 24, 2015 at 2:52 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    The steel wheel? I think those are close to around 32lbs.
  13. Jul 24, 2015 at 2:56 PM
    Dilleytech
    Jakob
    07 AC SR5 4x4
    Wow.. That is a large difference.. I better start saving coin. Those are some sexy rims
  14. Jul 24, 2015 at 2:57 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Given the same height and width a heavier tire will always get worse mileage and cause more wear than a lighter tire. Taller tires will help with mileage for folks who spend a lot of time on the highway and freeway (fewer starts and stops) because they run at a lower RPM. The rest of the claims, while completely sincere, are just mental error. Physics is physics regardless of what somebody perceives happens with their small and inconsistent sample size of miles driven.
    Justinlhc and Biscuits like this.
  15. Jul 24, 2015 at 3:00 PM
    #35
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Don't know why but 235/85-16 and 255/85-16 seem to come almost exclusively in ten ply. Dunno why. If I could find a C or D rating on a 255/85 that I wanted I would have taken the plunge on 33s.
  16. Jul 24, 2015 at 3:02 PM
    #36
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Not sure that is precise weight but I do know the steel wheels hover around 30lbs.
  17. Jul 24, 2015 at 3:15 PM
    #37
    Dilleytech
    Jakob
    07 AC SR5 4x4
    Better looking and maybe 8 pounds lighter win win
  18. Jul 24, 2015 at 3:19 PM
    #38
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I have BFG Ko2s 10 ply and duratracs 10ply both 265/75/16.
    KO's are on trd wheels
    Duratracs on American racing Ventura wheels.
    Didn't weigh anything but KO's on trd wheels feel heavier. I have a 4 banger 5 speed better mpg/power with the KOs using dash command connected to obd2 port. My experience with both hope the duratracs are better in snow than the KO's as they will be my winters.
  19. Jul 24, 2015 at 3:19 PM
    #39
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    #39
  20. Jul 24, 2015 at 3:21 PM
    #40
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    the 265/75/16 duratrac if C is 44 lbs
    the 265/75/16 duratrac if E is 51 lbs
    The 265/75/16 BFG KO2 if E is 53 lbs
