Load Range E tires - too hard?
Discussion in 'Wheels & Tires' started by andyt11, May 3, 2013.
  1. May 3, 2013 at 8:05 AM
    andyt11
    andyt11 [OP] Tiny Member
    Central Canada
    '13 TRD 6spd Dbl cab Leather
    Tekonsha P3
    I'm going to take delivery of a 2013 Tacoma, my first Tacoma. Looking forward to it. I also have a bit of a tire fetish! It's coming with 17" rims, 265/65/17 rubber. Nothing fancy. I have no plans to modify the truck, but I do like decent rubber.
    I drive on highway, construction sites daily, deep snow in the winter from time to time.
    For the last 6 or 7 years i've been riding around on BFG All Terrain KO's, I've been though two sets. I love them. Being snow rated too is a terrific plus and they have never ever been stuck anywhere unless they wernt touching the ground! But they were always Load range C, 6 ply tires.
    In a 265/65/17, the BFG AT KO only comes in Load Range E, 10 ply. Will that be too stiff and hard for a light truck like the taco? Anyone got any actual experience?
    Are there any other all terrain load range C snow rated tires out there that I could try instead?
    Would like to hear from anyone who has tried load range E tires on there taco. And suggestions for alternatives.
  2. May 3, 2013 at 8:10 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Personally, I believe load range E is overkill for a truck the size of a Tacoma unless you off road and need the thicker sidewall for puncture resistance. I would keep looking for a C rated tire, E is going to be a very stiff tire and will also negatively impact your fuel economy.
  3. May 3, 2013 at 8:16 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Very true. I do run KM2 E's on mine, as it sees alot of hauling and jobsite deliveries on access roads that are nothing but jagged blasted rock. I don't think it rides bad, but that is just my opinion. They are definitely heavier than a C and will negatively effect gas mileage
  4. May 3, 2013 at 8:22 AM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    I'm running 265/75R16 E's on my truck. Are they a little overkill, probably. I didnt notice a difference in ride quality, but between the lift and tires, I noticed about 1.5-2mpg drop.
  5. May 3, 2013 at 8:34 AM
    longstonec
    longstonec Member
    Whistler British Columbia Canada
    4x4, 4cyl
    My winter tires are studded Winterforce's in 10 ply.I do a fair bit of long gravel/ice/snow/gravel road driving it the winter. other then being loud and they arent too much stiffer.
  6. May 3, 2013 at 8:39 AM
    andyt11
    Central Canada
    Tekonsha P3
    The more I read, the more people write that D and E are too hard for a small truck like a Tacoma. A lot of unsprung weight too.
    If I go to a [FONT=Verdana,Helvetica,Arial] LT265/70R17, they are available in load range C. I wonder if I should just do that. I believe they will fit a stock taco without any issues.
    [/FONT]
  7. May 3, 2013 at 8:41 AM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    I have 245 e rated tires and I love them I still get great mpg
  8. May 3, 2013 at 8:45 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I've gone through around 5 sets of the bfg a/t's over the years and won't change... they're one hell of a tire. I'm running the e rated 265/75/16 now and have no complaints. The truck rides and handles better and feels like it's on tracks going around corners. Also, the tires handle the ruts in the roads around here better. Are they over kill? Probably, but i you can say the same thing for alot of the aftermarket things we put on these trucks.
  9. May 3, 2013 at 8:51 AM
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Speedway Blue 06 TRD Off-Road
    Leer 100XL Topper OME 885X/Nitrocharger Sport Front Dakar Leafs/Nitrocharger Sport Rear
    I went from E load BFG T/A KO 265/75-16s to C load DuraTracs in the same size.
    The ride is more compliant as expected, and mileage went UP according to my frequently calibrated/verified UltraGauge.
    The truck does wander a little more while rolling down the road as well as under heavy braking, but this might have as much to do with the fresh full-depth tread as the softer sidewalls.
    I'd say that 60% of my driving is commute, the rest is work/play either hauling something heavy in the back or pulling a 5x10 trailer full of whatever. The C loads have sufficient load capacity and work well for my needs. I don't see the need for E in my case.
  10. May 3, 2013 at 9:27 AM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    You can put 265/70/17's on stock wheels without lift and should not even have to loose front mudflaps.
    Those 265/70/17 C rated BFG's will be an inch taller, but still not as heavy as the smaller stock size 265/65/17 BFG E rated tires.
    22.8kg vs 20.4kg.
  11. May 3, 2013 at 8:10 PM
    drupp
    drupp Well-Known Member
    Pennsylvania
    '06 Access Cab TRD Off-Road
    I have had both D and E BFG ATs on this truck. For me, the D is much better.
  12. May 3, 2013 at 8:13 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I run the Michelin LTX M/S in a 265/75/16 that are E load range and they ride just fine. You can feel that they are a bit stiffer, but they ride very well.
    I only got E-load because thats all they had at discount in that size for that tire.
  13. May 3, 2013 at 8:28 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ditto.
    I ran "E" on my 3/4 ton Duramax. Would need them for heavy hauling and towing, but the Tacoma would be way overgross before getting close to making the E tires even take notice.
  14. May 26, 2013 at 9:30 AM
    mkillora
    mkillora Member
    2011 Tacoma
    I've got a 2011 Taco with the off-road package. Original equipment tires were BFG's 265/70R/16's. I regularly pull a travel trailer with a weight of about 2 tons. The BFG's were pretty much worn out at about 20,000 miles.
    My tire dealer suggested going to an LT tire and we installed Goodyear Wranglers. Big mistake. On a southern road trip to Florida this spring, the truck and trailer combination was pretty much undriveable. Felt like driving on ice the whole trip. The only variable that changed was the LT tires. Tried presssures from 40 psi all the way to 70 psi, which was recommended by Goodyear. Nothing worked. Now back at home and the tire dealer swaped the LT's back to the P rating. Installed Michelin's. Won't be taking another road trip until this fall, so wont be able to rate them, however, I'm confident that going back to the P rating will make the truck and trailer driveable again. LT's appear to be way toooo much tire for the Taco.
  15. May 26, 2013 at 9:37 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    70 PSI ?
  16. May 26, 2013 at 9:42 AM
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
    Goodyear Duratracs has load C Ride is great
  17. May 26, 2013 at 11:20 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    That's typically the sidewall limit for a load-range "E" tire.
    Load capacity is directly proportional to tire pressure.
    Heavier sidewall and tread construction support the higher pressure and load safely.
    A fully loaded Tacoma, hauling the heaviest trailer it is rated for, can not exceed the capacity of a load-range "C" tire.
    BUT... A load range D or E, run at higher pressures, will last forever.
    I had over 40k on the set of BFG KO's on my Duramax, ran them at about 60, and they still had at least 50% of their tread left, perfectly even wear across the face.
  18. May 26, 2013 at 2:37 PM
    OZ-T
    Peter North
    British Columbia
    I know that , my E rated ATm's have a max 80 PSI rating , I'm just not sure why you would ever run them at that if they were on a Tacoma
  19. May 26, 2013 at 2:49 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I took the leap and got some Duratracs load E 235/85 r16. They ride fine on a reg cab. Honestly, they seem to run as smooth as the stock at20s they replaced.
    With 4.56 gears turning them, I lost 2 mpg....23 down from 25mpg, only noteworthy but I don't really care how much I lost. Now I added the DT headers, might gain 1mpg, who knows.
    What is likely certain is that I cant really perceive much of a ride difference and the tire noise is lower frequency perhaps a bit quiter (due to a modern design I guess) and I went from a 33lb stock tire to a 46-48 lb tire, it will be harder to turn. aired down to 20psi they seem to quish still but less, I didn't try to really do a comparison here.
    Take your time and study the tires, I'm sure you'll make a decent choice no matter what you choose.
    As far as pressure I doubt I'll go over 50psi, I just don't know what the rims are rated for. I doubt I'd get over 40psi really on an 80psi tire, just wont be needed, like OZ said, for a Tacoma.
  20. May 26, 2013 at 2:59 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    The only up side I see in putting a load range E on a Tacoma is durability.
    They are heavy, so they hurt fuel economy, the Tacoma can not take advantage of the load carrying capability, they ride like a covered wagon when fully inflated, and when not fully inflated, their carrying capability is actually lower than a load range C or D at the same pressure.
    That pressure was fine for my Duramax... it was an 8000lb truck, and the combination of weight and having a real suspension damped the hard ride.
    "Mini" and mid-sized trucks have always had the suspension in the seats.
