Load Range? Tire Weight?
Discussion in 'Wheels & Tires' started by Ronin, Feb 9, 2010.
  1. Feb 9, 2010 at 9:53 AM
    Ronin
    Ronin [OP] iTaco
    Al
    Rockwall, Texas
    2008 Tacoma Sport 4x4
    low range leveling kit
    So, I was on the way to work this morning at stuck my truck:mad:! Sorry no pictures. Stuck it all the way to the front bumper. Put it in 4hi 4lo....no luck in the "black gumbo" around here. I honestly believe it would not have mattered what tire I had on my truck. Right now my truck has bridgestone HT(s). How does a 4x4 come w/HT(s)?
    Anyway, here is the question.
    Mudding and/or going through mud...doe the physical weight of the tire have anything to do w/the ability to go through the mud. Example: Load C vs. Load E.
    Part 2....would a Load E tire prevent the sidewalls from blowing out better than a Load C tire. Example: Off-Roading (hitting rocks).
    Part 3....Since BFG A/T KO have 3plys for the sidewall would it prevent the sidewall from blowing out better than a 2ply.
    Thanks for you input.
    -Al
  2. Feb 9, 2010 at 12:20 PM
    Ronin
    Ronin [OP] iTaco
    Al
    Rockwall, Texas
    so what is better new technology 2ply sidewall or ol'school 3ply
  3. Feb 9, 2010 at 12:22 PM
    Ronin
    Ronin [OP] iTaco
    Al
    Rockwall, Texas
    What is the technology difference between let's say Bridgestone A/T vs BFG KO's.
    KO's ol'school
    Bridgestone new school
  4. Feb 9, 2010 at 12:39 PM
    Ronin
    Ronin [OP] iTaco
    Al
    Rockwall, Texas
  5. Feb 11, 2010 at 2:31 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    Yes, weight matters...the lighter the tire the easier the truck can turn them...which is also why a lighter tire=better mpg.
    Yes, E rated tires have stiffer sidewalls and would hold up better to offroading over jagged/sharp rocks...for both questions...
    http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=55&
    "Today's load range/ply ratings do not count the actual number of body ply layers found inside the tire, but indicate an equivalent strength based on early bias ply tires. Most radial passenger tires have one or two body plies, and light truck tires, even those with heavy duty ratings (10-, 12- or 14-ply rated), actually have only two or three fabric body plies, or one steel ply."
    For example...it seems that all BFG AT KO are made with "Three-ply polyester carcass–TriGard® construction" so....the 'ply' number does not change with the load ratings C, D, E...so each of those load ratings have 3 ply's but have different load capacities which means stiffer sidewalls. The sidewall stiffness is what increases/decreases the load capacity and what has the biggest affect on ride quality.
