Load rating?
Discussion in 'Wheels & Tires' started by The_Hybrid_Hunter, May 31, 2024.
  1. May 31, 2024 at 6:49 AM
    The_Hybrid_Hunter
    The_Hybrid_Hunter [OP] Active Member
    2013 Tacoma Silver
    I have a 2013 Tacoma 4x4 base model sr5 6cyl
    I'm just beginning my overland build.
    This year is suspension, tires and rock sliders.
    I just put in Bilstein 6112's, 5160's, Icon RXT Leaf Packs (option2), OME upper control arms, Timbren bump stops front and rear.
    That's all I plan on adding except tires until next spring.
    Tires
    I'm confused on what load rating I should get?
    I use my truck primarily to drive forest service roads and two tracks for accessing the Wyoming backcountry for hunting, camping, hiking, mtn biking and backpacking.
    Can I get away with standard load rated tires or should I jump right into E rated?
    The only time my truck is weighed down is when the wife and I have both killed elk. Then we can be driving out of the backcountry with a load in excess of 600#
  2. May 31, 2024 at 6:53 AM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
  3. May 31, 2024 at 6:58 AM
    The_Hybrid_Hunter
    2013 Tacoma Silver
  4. Jun 4, 2024 at 12:12 PM
    dannybubbles
    dannybubbles yada yada
    Daniel
    Chico, CA
    01 3.4 auto 4x
    C rated is usually plenty, E rated is a little overkill, in my experience. (full size sprinter driven aggressively and fully loaded on C rated KO2s)
    Depending on what size you're looking for your options may be limited to one or the other, E rated will be heavier, stiffer, and more expensive all else being equal.
  5. Jun 4, 2024 at 5:45 PM
    RebleAZ
    RebleAZ Well-Known Member
    Troy
    AZ
    2020 Cement TRD Off Road
    Fox Performance Elite, RRW -25 RR7H, 295/70/17 Yokohama Geo MT. Alcan Leafs. Much more...
    For your purposes a C load seems like it would be fine. I have E and they are heavy and firm. I have piece of mind when on a trial though. I was considering going to a C load on my next set coming up soon though.
