Loaded Taco's Build
Discussion in '2nd Gen. Builds (2005-2015)' started by LoadedTaco, Jan 22, 2013.
  1. Dec 1, 2013 at 1:27 PM
    #241
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    Mona is a good name...
  2. Dec 2, 2013 at 7:21 AM
    #242
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Did you just go to town on that pinch weld or did you cut it a bit first into flaps then bash? Keep us updated on rubbing when you get out and flex!
  3. Dec 2, 2013 at 8:30 AM
    #243
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Lets see some pics. How much did you hack out of the fenders?
  4. Dec 2, 2013 at 8:44 AM
    #244
    LoadedTaco
    LoadedTaco [OP] Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    Honestly, I am not sure what the big deal was. Maybe I will need to hammer it more, but it took all of 20 min once the tires were off. I used a Creasent wrench to pull it out toward the outside of the truck. Then used a hammer to push it all the way back. The bottom was the only piece that required really hammering it hard. For that I used a big hammer for and used a piece of steel to spread the impact.
    I rub in a couple of spots.
    • Cab Mount (I will trim it a bit more)
    • Upper Control Arm (I'm on stock ones)
    • Frame (Not much you can do about this)
    Said tool
  5. Dec 2, 2013 at 8:58 AM
    #245
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Took out 2" which I would say is on the lower side compared to most, but I can always cut more.
    Flexing a little
  6. Dec 2, 2013 at 8:58 AM
    #246
    SconnieHailer
    Marc
    I've thought about putting my stock UCA's back on a few times because the dsm just add so much into it that I have to tell my alignment guy to set it at like 3.5* to get the same rear tire to body clearance as I did with the stock uca on in spec... Is there anything negative with running 4*+ of caster?
  7. Dec 2, 2013 at 9:56 AM
    #247
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    I am not sure what effect having that high of caster would have on your front end. Anytime alignment specs get far off, you will . I am kind of surprised that you need to crank it up that high to clear the 265s. Mine isn't anywhere near that with the 35's on. That seems kind of crazy that your UCA pushes your caster that far back.
  8. Dec 2, 2013 at 9:57 AM
    #248
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Looks really good Peter. If 2" is all it takes than that's good. I took 2" out of my fronts last night. KM2's will be in this afternoon.
  9. Dec 2, 2013 at 10:54 AM
    #249
    SconnieHailer
    Marc
    I dont need it per say to clear the 265's I just like the wheel centered in the well. I got the DSM's because they supposedly had the least caster built in. :notsure:
  10. Dec 2, 2013 at 2:21 PM
    #250
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Sweet I can't wait to see your truck with 35's on it!
    That would make sense, seeing as the lower the caster the further back it sits.
  11. Dec 2, 2013 at 2:54 PM
    #251
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Uhh ohh! Guess what came a day early?
  12. Dec 2, 2013 at 2:56 PM
    #252
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Sweet, underwater breathing apparatus
  13. Dec 2, 2013 at 3:01 PM
    #253
    SconnieHailer
    Marc
    I just realized after looking at that pic that the airflow snorkel looks just like a kangaroo leg! :rofl:
  14. Dec 2, 2013 at 3:46 PM
    #254
    Manwithoutaplan
    ID
    very nice. just don't understand why they are so much :/.
  15. Dec 2, 2013 at 5:30 PM
    #255
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Because it lets everyone know you're a real wheeler! :laughing:
  16. Dec 3, 2013 at 7:22 AM
    #256
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Right!? It's still just plastic.
    Haha! Honestly, the main reason I got it now, is because of how exposed my intake is without the liner in the wheelwell.
  17. Dec 3, 2013 at 7:24 AM
    #257
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    That's a great reason, helps a ton in dusty conditions as well. Pretty much same reason I did it. Nice security in water crossings but those are few and far between
  18. Dec 3, 2013 at 10:27 AM
    #258
    Manwithoutaplan
    ID
    tyler does the snorkel get in the way of your line of site.
  19. Dec 3, 2013 at 10:27 AM
    #259
    Manwithoutaplan
    ID
    very true.
  20. Dec 3, 2013 at 11:02 AM
    #260
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    I have a Dewalt 105mm hole saw and mandrel I'll make you a good deal on. Only used once :D
