Loading a gun safe onto the tailgate OK?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 230g Hydra-Shok, Jan 31, 2008.
  1. Jan 31, 2008 at 8:00 AM
    230g Hydra-Shok
    230g Hydra-Shok [OP] Active Member
    2008 V6 blue access cab TRD with 6-speed
    Having a 500lb gun safe delivered soon. Instead of having the delivery guy lower it to the ground, I'd like to simply back my 2008 TRD up to the lift and have it lowered to the bed of my truck.
    Should I worry about the tailgate supporting it for a few seconds until we can lay it down in the bed?
    Would it be better to avoid the center part of the gate and have it placed on the side instead?
    Thanks. :D
  2. Jan 31, 2008 at 11:31 AM
    230g Hydra-Shok
    Hmmm, I appreciate that. I didn't know the tailgate came off easily. Is there a how-to in the owner's manual? I flipped through it for an hour or so when I bought the truck but don't recall seeing it mentioned.
    If it comes off easily, that's definitely what I'll do! Thanks again. :)
  3. Jan 31, 2008 at 12:07 PM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    i'd just have em lay it down and load it up
  4. Jan 31, 2008 at 2:58 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Take the tailgate OFF...... and don't worry.
  5. Jan 31, 2008 at 4:18 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    pop off the cables, close the tailgate to within a few inches of closed, and pull up on the passenger side. The hinge peg on that side is squared off and lines up with a notch on the tailgate. Once the passenger side is off, pull to the passenger side to get it off the driver side peg.
    I would take the tailgate off, lay the safe down in the truck, and slide it into your bed. It would probably be easier (less lifting) and no worry about breaking the tailgate.
  6. Jan 31, 2008 at 7:49 PM
    Flycatcher
    Flycatcher Master of the Universe
    Minnesota
    2009 Acadia (regretfully sold the Taco)
    New guy here chiming in. DO NOT LOAD ANYTHING on that cheap a$$ flimsy tailgate. I had a ball & burlapped tree forked into the bed. I am pretty sure it didn't weigh 500lbs. When I got it home, it took 3 landscapers to roll it out and onto a wheelbarrow. As soon as they rolled it across the tailgate that damn thing folded like card. It's pretty flimsy. The composite inner surface has no strength and is only supported in a few places buy thin strips of sheet metal. You can remove the allen key bolts and see for yourself. I got a good look when I got the new tailgate since they come without the composite liner. Luckily that part popped back out or I would have had to buy that too. Only the outer sheet metal was kinked beyond repair. It was $230 for the tailgate and then another $200 to get it painted. Lesson learned.
  7. Jan 31, 2008 at 10:16 PM
    natrlyst
    natrlyst Well-Known Member
    I agree with ndcouch, I load a quad weekly riding right up on to the tailgate before pushing it into the back of the truck, do not worry about the weight, it will be fine, if you chosoe to take the tailgate off (I personally believe it is not necesary), it is extremely easy, try it before wasting time reading the manual. Have a look at it and you will see how it comes off!!
  8. Jan 31, 2008 at 11:46 PM
    TuRDTACO
    TuRDTACO Carolina Alliance: Midwest Firearms Division
    joliet, il
    HAD 07 TRD OFFROAD PRERUNNER
    small dent on the hood, new foglight bulb, roughed up bedliner, been smoked in, suspicious stains on the passenger seat, boogers on the drivers seat, dirty floor mats, girl doodles on the dirty windows, loose wiring
    haha here is something i've done before! about a month ago i rested a 525lb gun safe on the tailgate while we lifted and slid it in, and i didn't have a problem with it. tailgate didn't sag or bend or anything so you should be fine, just do it fast. i also did it dozens of times with quads
  9. May 15, 2008 at 12:42 PM
    danusa
    danusa Well-Known Member
    There is a TSB. I have not wrecked mine.
    As to a preivious post; I am packing an M9 with MIL Spec.Laser and Fed Hydro shocks at the moment.
    I do not wish my weapons to be lonely.
    The 1911`s get most of the attention. The 870 is always around. The SAA`s and other revolvers get some powder burnt. I used to pack a SAA as a duty weapon. Lawerence and Don Hume made the leather.
    I only have so much time.
  10. May 15, 2008 at 1:11 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    i live in WI so I can't even touch the Vehicle with the gun if its not in a case. TOTAL BS
  11. May 15, 2008 at 1:46 PM
    danusa
    I am also in WI right now. But I am exempt.
    What Peace Officer does not cover the DoD does.
    WI does not forbid MG`s. But does auto knives except for Mil.
    Even civilian cops and EMT can`t pack them.
