Loading on truck causing rear to sink.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bruce1271, Mar 16, 2010.
  1. Mar 16, 2010 at 11:18 AM
    bruce1271
    bruce1271 [OP] Well-Known Member
    I just got back from a camping trip. Had about 500 pounds in the cab and about 400 in the bed. The back of the truck seemed to sink more than I expected from such a small load. I felt like I bottomed out a few times on the trip on the highway as well. Its an 05 V6 pre-runner double cab. I may need new rear shocks, but I didnt expect the truck to sink this much and it felt loaded when driving. Any ideas on how to fix? I guess adjustable shocks for load vs no-load? Anyone experience this as well? I expect it to go down some, but what If I were towing as well. That would have killed me I think.
  2. Mar 16, 2010 at 11:19 AM
    JKD
    JKD Well-Known Member
    500 pounds total in the cab (people plus cargo), or 500 pounds of cargo in the cab?
  3. Mar 16, 2010 at 11:23 AM
    bruce1271
    500 pounds of people + 400 pounds of gear in the back.
  4. Mar 16, 2010 at 11:30 AM
    Patrick
    Patrick Well-Known Member
    I loaded my truck up with wood and all my camping gear. I dont know the weight drove 6 hours south to Valdez through the mountains. It ran like a champ, only downfall was i had to downshift my 4 cyl on some of the steep grades but gas was good.
  5. Mar 16, 2010 at 11:56 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    if you don't qualify for the TSB to be done on Toyota's dime, spend $100 and get an AAL. It'll take you and a buddy about an hour and a hlaf to do both sides. Well worth it.
    I recently did this myself.
  6. Mar 16, 2010 at 12:00 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Count your leafs, betcha got 3 on each side. Do the AAL as was suggested.............
  7. Mar 16, 2010 at 12:04 PM
    curt05
    curt05 Member
    Curt
    Dallas, TX
    05 4x4 v6
    Add-a-leaf. That is the fix to your problems.
    I have used the AAL that comes from Toytec.com. You can't go wrong.
  8. Mar 16, 2010 at 12:04 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The AAL works good at fixing the sagging problem. However if you are hauling a lot of weight they springs still don't hold up too well. Another option (whether you have the TSB or not) is the Timbrens. They retain your factory ride, but when you start loading up gear, or haul a trailer, they prevent your truck from sagging too much, yet still allow the suspension to cycle properly.
  9. Mar 16, 2010 at 12:05 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Helpful Link : http://www.toyotanation.com/forum/showthread.php?t=258979
  10. Mar 16, 2010 at 12:19 PM
    brg88tx
    brg88tx Well-Known Member
    i got a half yard (1500 lbs) of topsoil in the bed of my 03 prerunner doublecab last week and my ass was seriously saggin.
  11. Mar 16, 2010 at 1:46 PM
    bruce1271
    So, AAL and Timbrens are my two options. I see the Timbrens only have 1" of travel before they are engaged. I wouldn't think this would be enough to keep the original ride of the truck(unless they engage with minimal resistance and slowly). Looks like Timbrens are around $200 and AAL is around $100. What to do...
  12. Mar 16, 2010 at 1:56 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Leaf spring helper at local autozone for 25 bucks is the best bang for the buck IMHO for what most guys need.
  13. Mar 17, 2010 at 6:11 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I hauled 1500lbs with my 1/2 ton truck with 3 leafs + AAL. Held up fine and went right back where it was when eptied.....but I don't do this very often.
  14. Mar 17, 2010 at 8:11 AM
    bruce1271
    Pretty sad Toyota didnt think of actually loading the truck before selling it and finishing the design. I mean really.
    thanks for all the feedback.
  15. Mar 17, 2010 at 8:57 AM
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    As said before, get the Rear Spring TSB or and AAL. I got the rear spring TSB done a couple months ago and it made all the difference in the world. Now I have a functional truck.
  16. Mar 17, 2010 at 9:04 AM
    Kawasaki
    Kawasaki Beer is proof God loves us.
    I got some Hellwig helper springs (1000lb rating) and it helped a lot (~$120). I had a camper shell installed and I noticed the rear suspension sitting further down. Drove it for a while hauling bikes and gear. I eventually decided to invest in the helper springs. Worked great for me. Feels like I got my travel back when it's loaded.
    My $.02.
  17. Mar 17, 2010 at 9:58 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    Airbags are another option.
    Replace bump stops with airbags and control how much pressure with air fittings.
    Mild to wild.
