Local BHLM
Discussion in 'Northern California' started by mhshark, Oct 31, 2017.
  1. Oct 31, 2017 at 6:18 PM
    mhshark
    mhshark [OP] Well-Known Member
    Bend, Or
    I absolutely love the look of the Tacomas with black out headlights but I’m far too afraid to bake mine and go through that. Is there anyone trusted local to the Bay Area that does this? I’d like to support someone local, if not I guess my best option will be the mail off services that some guys on here provide.
    Any info helps!
  2. Nov 1, 2017 at 12:51 PM
    gargamel05
    gargamel05 Well-Known Member
    Bay Area,CA ---> Easton,PA
    I was in the same boat. So happy I found a set of Pro headlights for cheap to buy.
  3. Nov 1, 2017 at 1:09 PM
    CalTacoma09
    CalTacoma09 Well-Known Member
    Manteca, CA
    09 TRD Sport DCLB 4x4 Barcelona Red
    A lot of crap and too much money spent
    BHLM It's not that hard. Try going further with a retrofit where you have to cut into the dish. Now that's a little nerve racking.
    eccracer104 likes this.
  4. Nov 1, 2017 at 1:51 PM
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    Let’s take this to it’s logical conclusion...
    Just imagine, if you can, a set of Pro lights that are retrofitted...
    Woah(insert Keanu Reeves meme here)!
    gargamel05[QUOTED] likes this.
  5. Nov 1, 2017 at 10:25 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Haven't done my Taco but on my honda here were some tips. It's not too hard but takes time to do it right
    1. Use lowest heat setting on oven
    2. Use cookie sheet or flat surface to prevent melting grooves in tabs
    3. Pry light open SLOWLY...
    4. Use a heat gun or put back in oven if it cools and doesn't want to open
    5. Sand shroud and clean thoroughly and primer before painting (to avoid peeling)
    6. Let paint cure for 24 hours+ before reassembly to prevent hazing
    7. use alcohol to and lint free cloths to wipe lens clean and reassemble in a clean environment.
    8. Reseal with plenty of extra caulk (tape edge of lens before caulking to avoid runover)
    Good luck, definitely doable. Or you can buy some DEPO headlights that are already blacked inside.
    https://www.amazon.com/Depo-312-1186P-US2-Toyota-Tacoma-Headlight/dp/B005XRPNYI
    CalTacoma09 likes this.
  6. Nov 9, 2017 at 1:19 PM
    mhshark
    Bend, Or
    If you do let me know. Would love to do it in the next few months
  7. Nov 9, 2017 at 3:32 PM
    Savage707ron
    Savage707ron Well-Known Member
    2017 trd off road
    I ended up not doing it. I don' have th patience. might be selling my morimoto resealant kit though.pm if iterested.
  8. Nov 9, 2017 at 3:34 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
  9. Nov 9, 2017 at 4:01 PM
    mhshark
    Bend, Or
    Yeah a 2017
  10. Nov 9, 2017 at 4:05 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Ah, I have some 12-15 Tacoma headlights for sale and am headed up to norcal next week. They won't do you any good though, wrong year. Best of luck :thumbsup:
  11. Nov 9, 2017 at 4:25 PM
    mhshark
    Bend, Or
    Thanks for looking out my dude!
    eccracer104[QUOTED] likes this.
