local DT over wrenched my nuts! WTD
Discussion in 'Discount Tire Direct' started by GQ7227, Aug 20, 2019.
  1. Aug 20, 2019 at 7:29 AM
    GQ7227
    GQ7227 [OP] mw survivor
    J A Y
    one of their dudes wrenched one of my lugs on super uber tight during rotation couple weeks back
    had a PITA pain in rear getting it off to get drums powder coated
    are those lugs supposed to be that friggin tight that i cannot easily take off by hand??
    what the heck happen should i have a flat out in nowhere with a super tight lug???
  2. Aug 20, 2019 at 7:33 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    They are suppose to be Around 85 foot pounds of torque
    GQ7227[OP] likes this.
  3. Aug 20, 2019 at 8:53 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    GQ7227, Thank you for your support!
    The torque specs should be listed on your invoice. The techs use a torque wrench set to what ever the vehicles call for when torquing them. If there is a problem I would recommend speaking to the local store Manager. Your 97 Tacoma shows as being 85
    uploadadventure and GQ7227[OP] like this.
  4. Aug 20, 2019 at 8:54 AM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Should be torqued to 87 or 89 ft/lbs. per the manual!
    GQ7227[QUOTED][OP] likes this.
  5. Aug 20, 2019 at 9:09 AM
    GQ7227
    J A Y
    thanks for the specs!
    not sure how I would know the torq when doing it by hand with the supplied wrench in the back of the cab :notsure:
    maybe the nuts are just very old and need replaced?
    i priced some new ones at ~$7 each online @ Camelback, my local dealer probably wants $15 each for them, i will check!
