Location of a Blown head unit fuse
Discussion in 'Audio & Video' started by tacomatrdod, Apr 9, 2013.
  1. Apr 9, 2013 at 6:13 PM
    tacomatrdod
    tacomatrdod [OP] Well-Known Member
    Mud Country
    2010 tacoma trd offroad
    Toolbox, stereo upgraded a tad
    Where abouts would it be? I've looked inside my manuals that came with the truck rather thoroughly, and have found nothing, there's something called the "head" on the fuse box inside the cab... i'm so close to just checking every fuse as my head unit wont turn on.
  2. Apr 9, 2013 at 8:19 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Hi, I was just wondering if your radio is stock or aftermarket. An aftermarket head unit has a fuse located directly on the rear of the head unit.
  3. Apr 10, 2013 at 9:04 AM
    BamaToy1997
    Bill
    Navarre, FL
    There are 3 possible fuses that are part of a factory radio. One is the ACC fuse located in the dash panel fuse block. Then you have "radio 1" fuse and "radio 2" fuse located in the under-hood fuse block. (Left front of engine compartment)
    wilcam47 likes this.
  4. Apr 10, 2013 at 2:16 PM
    tacomatrdod
    Mud Country
    Well i've checked all of them and some more fuses, and none are blown. ALso the cigarete adapter is also not working, and apaprently one needs the other to work.. and more ideas as to why it isn't working would be much appreciated!
  5. Apr 10, 2013 at 2:56 PM
    BamaToy1997
    Bill
    Navarre, FL
    OK. Just going back through this, you mentioned the head unit wont turn on, and you have included that the cigarette lighter/power port is inop as well? Lets get into a bit more detail then. Do you have the built in amplifier option, or not? That information may help a little. Also, do you have ANY display at all? (Clock, illumination, etc) on the radio?
    Also, when you checked the fuse, did you just look at it, or did you actually use a test light to verify it had power on both sides of the fuse? The ACC fuse supplies power to the radio, as well as a relay that sends power to the cig lighter. That is why I asked.
  6. Apr 12, 2013 at 4:02 PM
    m0sing808
    m0sing808 Well-Known Member
    where exactly is the acc fuse??
  7. Apr 16, 2013 at 9:19 PM
    tacomatrdod
    Mud Country
    I'm away from my truck in Florida, but will be back soon. If I didn't blow a fuse what's up next on the check list?
  8. Sep 14, 2020 at 7:49 PM
    Christrd2018
    Christrd2018 New Member
    2018 Tacoma Trd sport
    Hello, I have the same problem on my 2018 taco and yes I have build an amp and one day the wire That come from the radio to the amp make contact to the chassis accidentally and immediately my radio turn off.
    I check my fuses and all look good, I also check the oEM radio and there is not a fuse. Is there anything else that I can check.?
    Please help.
  9. Sep 15, 2020 at 2:56 AM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    The ACC fuse is the 7.5A fuse in the panel by your left knee from the driver’s seat.
    Use a meter when checking fuses.
  10. Sep 15, 2020 at 5:10 AM
    Christrd2018
    I will do that and see if work. Thanks!!
