Location of EGR and IAC valves on 2.7L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ninjalicious1985, Mar 19, 2016.
  1. Mar 19, 2016 at 7:56 PM
    Ninjalicious1985
    Ninjalicious1985 [OP] Well-Known Member
    Vancouver Island
    2012 Tacoma 2.7L 5 Speed Manual
    Hello everyone,
    I am going to be doing a spring tuneup of my Taco this April and want to check the EGR and IAC valves on the engine.
    Does the 2.7L even have these parts on them? If so, where are they located?
    Thanks,
    James
  2. Mar 20, 2016 at 9:08 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No. There is no EGR Valve or Idle Air Control Valve on the 2012 2TR-FE 2.7 Liter Engine.
    You may want to check the PCV on the rear of the valve cover on the passenger side. It is a screw in type.
  3. Mar 20, 2016 at 10:45 AM
    Ninjalicious1985
    Vancouver Island
    Thanks! Correct me if I'm wrong, but should the PCV rattle when I shake it?
  4. Mar 20, 2016 at 1:18 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes. It acts as a check valve to allow flow from the valve cover to the intake and block flow in the other direction.
  5. Apr 8, 2016 at 1:05 PM
    Ninjalicious1985
    Vancouver Island
    You mentioned that there is no idle air control valve on this engine. Is there something that takes its place that controls your power steering, accessories, etc? How do you check this?
  6. Apr 8, 2016 at 1:14 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I don't even know what you are asking here? The engine idle is computer controlled. There is no IAC Valve nor a EGR Valve,
    What does that have to do with power steering and accessories?
  7. Apr 8, 2016 at 1:50 PM
    Ninjalicious1985
    Vancouver Island
    Older cars have an idle air control valve so when someone is turning and puts a load on the engine via power steering, the IAC tells the computer to increase the power to compensate.
    If the the 2TR doesn't have IAC, then how does the computer know when to increase power in situations like slow speed turning?
    Hopefully that clarifies the question for you.
  8. Apr 8, 2016 at 9:12 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Engine control systems are much smarter than they used to be as evidenced by the ass load of sensors etc. Such as the AC System when it comes on it sends and Idle Up Signal to the ECU to initiate an increase in idle speed. With all of the sensors it is constantly adjusting for changing conditions.
    Read this:
    https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwjW2c6V1oDMAhVK1CYKHdx2Bg4QFggzMAM&url=https://www.tradebit.com/usr/wisark/pub/9003/Toyota_Hilux_Service_Repair_Manual_Complete_INFO.pdf&usg=AFQjCNF0yftMIU6cMmxpQtWU6qnzYwJVhw&cad=rja
  9. Apr 8, 2016 at 10:43 PM
    Ninjalicious1985
    Vancouver Island
    Holy smokes. That literally answered all my questions. Thanks a bunch! :)
  10. Apr 10, 2016 at 7:36 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No problemo dude!
