Locations - Out Of Site - Factory Looking
Discussion in 'Audio & Video' started by tommyxv, Sep 29, 2010.
  1. Sep 29, 2010 at 12:47 PM
    tommyxv
    tommyxv [OP] Well-Known Member
    Delaware
    '11 DC 4x4 TRD Sport
    For those who have added an aftermarket HU with the following addons: Sat Tuner Box, iPod cable, BT Mic, Nav Antenna, etc.... please post you locations and wire run paths. And is you have had an issues or problems.
    I am installing a Double Din Nav next week with the above addons. It will probably take me two days. LOL
  2. Oct 1, 2010 at 6:38 PM
    DevL
    DevL Well-Known Member
    Mic next to the rear view mirror. Nav antenna under the dash centered up front. Works great. Buttons for rear view camera and voice control on left side of tunnel. Mic run up driver A pillar.
  3. Oct 1, 2010 at 7:00 PM
    tommyxv
    Delaware
    Thanks..., is there room behind the dash for the XM tuner box?
  4. Oct 2, 2010 at 12:24 PM
    DevL
    There are tons of nooks and crannies. Mostly toward the center of the dash and glove box area. Pulling your glove box down will give you a good view. Open the glove box and pull out the shock lowering device, then you can pop out the glove box. From there you can see your AC blower motor and all the spots on the right side of the dash. Its the easiest to get to. The center of the dash requires pulling multiple pieces off and lots of faith your not going ot break something you are pulling so hard and there is less room there anyway. Just room where all the wires go behind the radio... thats where the hidden GPS antenna is. Tons of room under the center tunnel except around the cup holder. Its mostly just one piece and all you have to do to get it off is remove the handle on the shifter and lift it off.
