lock a sport?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTRD59, Nov 14, 2016.
  1. Nov 14, 2016 at 9:49 AM
    TacoTRD59
    TacoTRD59 [OP] Well-Known Member
    2012 Tacoma TRD
    what exactly would I need to add locker to a sport?
  2. Nov 14, 2016 at 10:27 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    a locking rear diff of your choosing that matches the gear ratios you have
    and a way to activate it
    if you mean an OEM toyota e-locker, then that, plus make sure the gears match,
    and the dashboard and ecu wiring to go with it
  3. Nov 14, 2016 at 10:29 AM
    TacoTRD59
    2012 Tacoma TRD
    so theoretically if I can find a totaled Off-road, i can take the diff from it and it should drop in? along with wiring and whatnot?
  4. Nov 14, 2016 at 10:31 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    yes
    just confirm the gear ratios so you don't blow up the tcase --if this is a 4wd--.
    2wd doesn't matter, but you just gotta make sure if you have 4wd that the the rear you put in, matches
    should be on the door sticker or listed somewhere on this site.
  5. Nov 14, 2016 at 10:31 AM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    I might be dumb but don't you need the whole axle? I know with first gens you do since the motor is external. Which is why some choose the easier route of an air locker.
    AR15xAR10 likes this.
  6. Nov 14, 2016 at 10:33 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    wsurunner likes this.
  7. Nov 14, 2016 at 10:34 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Sport and off-road models have different size rear ends, you can't just take the third member from one and swap it to the other.
    Please someone correct me if I'm wrong, but I believe the sport has a larger rear end.
    ODNAREM, shakerhood and MotoEd like this.
  8. Nov 14, 2016 at 10:35 AM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    yes, sport has the larger and beefier rear end.
  9. Nov 14, 2016 at 11:00 AM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    2005 Silver DCLB 4x4
    ARE Shell. Pelfreybilt front bumper. hi-clearance rear bumper w/swing out. Rigid light bar/fog lights/reverse lights. Pelfreybilt front skid. Home/hand made slidders. DR front coilovers. Camburg UCA. AllPro Expedition leaf pack w/u-bolt flip and Timbren bump stops. 285 70-17 on stock rims with Spider Trax wheel spacers. EBC slotted/drilled rotors with green pads.
    I read on lowrange off-road web site that the e-locker has 8" ring and pinion gears while the non e-locker has 8.4" ring and pinion gears. So I don't think you can just get the e-locker 3rd member and bolt it up to a sport axle. You might have to do an axle swap to get the Toyota e-locker in a sport. I'm in the same boat.:frusty:
  10. Nov 14, 2016 at 11:19 AM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    Found a sweet mechanical conversion for the e-locker so you don't have to wire everything up. Replaces all the wiring and actuator to a mechanical setup. You just have to mount a lever in the cab.
    http://www.chilkatdesigns.com/E-Racer.html
  11. Nov 14, 2016 at 11:24 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    COWBOYS NATION!!!!!!!!!!!!!!!
    :headbang::headbang::headbang::headbang::headbang::headbang::headbang::headbang::headbang::headbang:
    Scribbles and TacoTRD59[OP] like this.
  12. Nov 14, 2016 at 11:38 AM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    A Lunch box locker is a cheaper route. There are several companies out there that make them.
    Pabloeeto likes this.
  13. Nov 14, 2016 at 11:43 AM
    eon_blue
    Azusa, CA
    Yes you would need the whole axle, the sport diff is a different size than the OR one.
    Be easier to get an ARB air locker installed in your current diff
    ODNAREM and MotoEd like this.
  14. Nov 14, 2016 at 11:44 AM
    Justinlhc
    Justinlhc Not looking for a relationship
    Make sure you do your research on lunchbox lockers if that's the route you go. They're not as street friendly as an LSD or e-locker/air locker setup. Lots of clicks and pops during turns and in parking lots. They're not for everybody.
    MotoEd likes this.
  15. Nov 14, 2016 at 12:33 PM
    TacoTRD59
    2012 Tacoma TRD
    any way you can link me to exactly what i would need? I'm not a mechanic, in fact i barely know anything about the vehicle other than how to have fun in it. My old 2004 was an off road and the locker helped me in the snow. I frequent West Virginia and where my place is, the roads are downright sketchy as fuck when it snows.
  16. Nov 15, 2016 at 3:42 PM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    For snow country the ARB is your best bet, you can turn it off when it's slick & your truck will run 100% like it does stock. Turn it on for the trail and it's locked instantly. http://eastcoastgearsupply.com/i-788575-tacoma-8-4-non-eld-t100-tundra-3rd.html This company will build the whole unit and ship it to you, then you can do the swap and ship them your stock unit for a core exchange refund, I think it's $400 back once they receive yours. Tons of people on this site have used them, good folks. You'd also need an air compressor or air tank permanently installed in the truck to run this unit. Probably about $1,500-2k to do it, depending if you DIY or pay a shop to bolt it all up.
    If you have a different vehicle you can drive on the slick roads then lunchbox lockers are another option. They lock up when the throttle is applied, but spin the inside rear tire at the blink of an eye when you're making a turn. This is why they aren't suggested for slick roads. I live in So Cal and have driven once in the rain, it wasn't fun but I made due. Ice would be a deal breaker for me. These lockers only run about $400 and installation can be DIY with some how-to's or a shop can do it in a few hours for a penny.
  17. Nov 15, 2016 at 4:49 PM
    Pigpen
    Dan
    Northwest Montana
    Go with the ARB option from ECGS. You'll be glad you did.
    Skootter14 likes this.
  18. Nov 15, 2016 at 8:26 PM
    TacoTRD59
    2012 Tacoma TRD
    There is no electronic locker? Something I can just hit a button?
  19. Nov 15, 2016 at 8:30 PM
    eon_blue
    Azusa, CA
    The ARB air locker is selective just like the e-locker. Just flip a switch and you're locked, flip it again you're unlocked.
    There is a new aftermarket e-locker I read about recently for Tacomas, made by Harrop I think...they were only making them for Hilux's but they are selling them for Tacomas now through another company if I remember right. Can't remember the name though...
  20. Nov 15, 2016 at 9:10 PM
    TacoTRD59
    2012 Tacoma TRD
    Ok next question, I see an entire kit and compressor on LowRange, what gear ratio do you guys think would be best for both worlds? On and off road. Currently running 275-70 KO2s
