Lock Button not locking driver Door
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dannybten23, Aug 28, 2017.
  1. Aug 28, 2017 at 2:10 PM
    dannybten23
    dannybten23 [OP] Active Member
    When I hit the lock button on the driver door, the driver door does not lock (the passenger door does lock). Any advice?
    I can manually lock the driver door with the key or by pushing the lever (the part with the orange sticker showing when it is unlocked).
    Any help is appreciated!
    Danny
  2. Aug 28, 2017 at 2:12 PM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    There are settings from the nav screen that enables you to choose which doors lock and unlock when you lock the doors. Not sure if it's for the key fob or door handle only, but you can give it a shot.
  3. Jun 6, 2019 at 11:20 PM
    dannybten23
    I don’t have a nav screen.
    Sometimes the door locks. Sometimes it doesn’t.
  4. Jun 7, 2019 at 1:26 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Sounds like your door latch is bad (the electrical part of it).
    We see a lot of these going bad in the Lexus world.
  5. Jun 7, 2019 at 5:13 AM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    Pull apart door, remove solenoid/latch assembly.. clean with degreaser, use a good lithium grease spray to lube.. reinstall and check function.. if it fails to unlock/lock again, replace the latch assembly. should take no longer than 30 minutes to get it out.. 30 min to re-install. solenoid may just have become weak, or the mechanism inside it may be severely worn..
