Lock Out Hubs and Locking Rear Differential For 1st Generation Tacomas
Discussion in '1st Gen. Tacomas (1995-2004)' started by Perro Viejo, Nov 13, 2015.
  1. Nov 13, 2015 at 8:27 PM
    Perro Viejo
    Perro Viejo [OP] New Member
    2004 Toyota Tacoma SR5 4x4
    Starting from stock...
    What do I need to do to be able to install Warn or similar lock out hubs on my 2004 XtraCab 4x4 Tacoma?
    How difficult/expensive is it to convert the rear differential on a 2004 XtraCab 4x4 Tacoma from the original standard SR5 differential to the TRD locking differential?
  2. Nov 13, 2015 at 8:41 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Can't swap in just the rear diff. Have to swap in the entire axle.
  3. Nov 13, 2015 at 9:08 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
  4. Nov 13, 2015 at 9:10 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Aisin hubs for sure.
    Lots of rear locker threads if you look around.
