Lock out hubs
Discussion in '1st Gen. Tacomas (1995-2004)' started by clawm1, Sep 10, 2025 at 9:59 AM.
  1. Sep 10, 2025 at 9:59 AM
    clawm1
    clawm1 [OP] Member
    Mark
    Can I swap lockouts if I can find them?
  2. Sep 10, 2025 at 10:08 AM
    Wulf
    rock raisin
    welcome to TW!!
    unfortunately the manual hubs are not a direct swap. It will require a different wheel bearing and CV axle as well at a minimum.
    The wheel bearings can be pressed into your existing spindle, then the manual hubs CVs require no modifications to fit the differential or spindle side when used with the manual hubs.
    That said, the swap might be worth the effort if you put a ton of mileage on your truck. I pick up 2mpg with my hubs unlocked
    Area51Runner likes this.
  3. Sep 10, 2025 at 10:18 AM
    clawm1
    clawm1 [OP] Member
    Mark
    Thanks for the welcome
    Well I was afraid it wasn’t a simple swap
