Lock the rear dif in 2 wheel or 4 wheel hi?
Discussion in 'General Tacoma Talk' started by Pastrychefreh, Apr 17, 2023.
  1. Apr 17, 2023 at 9:08 AM
    Pastrychefreh
    Pastrychefreh [OP] New Member
    Roger
    Black 18 off road
    I know on the older FJ that you could ground the gray wire to make the computer think you were in 4low. That way you could lock the rear dif in 2 wheel or 4 wheel hi. I have a 3gen (2018) and was wondering if anyone has done this or knows about it
  2. Apr 20, 2023 at 9:57 AM
    hotdog41
    hotdog41 Member
    Pike Co. Kentucky
    2001 TRD 2023 TRD OR
    I done that mod on my 2001 Tacoma, it was handy to be able to lock the rear differential in while in 2wd. I don’t know if it can be done on the 3 gen trucks or not. Maybe someone will chime in that has more knowledge on this.
  3. Apr 20, 2023 at 10:12 AM
    Mad German
    Mad German Well-Known Member
    2016 TRD Off Road
    You can't lock the rear in 2HI or 4HI from the factory. You can mod it to do that, however. Not sure how to do it, but I believe I've heard of guys doing it.
  4. Apr 20, 2023 at 10:19 AM
    Shellshock
    Iowa
    Nope not with the factory locker. You can get an aftermarket locker.
    SR-71A and Mad German like this.
  5. Apr 20, 2023 at 10:37 AM
    Mad German
    2016 TRD Off Road
    It would probably be a better locker too.
    Shellshock[QUOTED] likes this.
  6. Apr 20, 2023 at 10:40 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Correct. From what I read 3rd gens are an electro magnet instead of a motor driven actuator. No such mod has been developed yet for them (surprisingly)
  7. Apr 20, 2023 at 10:51 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It can be done.
    But not “easily” and you eliminate the safety factor for engagement.
    If one has the time, the information can be obtained in the link below.
    Personally, it’s too much work. I’d wait for a Plug n’ Play development first.
    https://www.tacomaworld.com/threads/rear-diff-lock-anytime-mod-3rd-gen-development.537810/
    hotdog41 and SR-71A[QUOTED] like this.
  8. Apr 21, 2023 at 6:46 AM
    stu8319
    stu8319 Well-Known Member
    Stuart
    Oklahoma City
    2018 Tacoma TRD Off-Road in Quicksand
    What makes a locker better? Durability? I'm no rock crawler, but every time I've needed the factory one it just works.
  9. Apr 21, 2023 at 10:20 AM
    TnShooter
    Deogee
    STOCK
    The 3rd Gen trucks have a beefier carrier and larger gear set. They now use an 8.8” gear vs the 2nd Gen 8.0”
    I have not seen too many busted 8.8” on the 3rd Gens.
    I wouldn’t worry about durability. They even changed the the way the locker engages.
    The 3rd Gen doesn’t use an electric motor like the previous gens, so you don’t have to worry too much about water destroying the actuator.
    I think you’ll be just fine with what you have. :thumbsup:
    stu8319[QUOTED] likes this.
  10. Apr 30, 2023 at 1:16 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    2wd low mod will allow you to engage the locker in 2wd low, in addition to 4wd low.
    I've not heard of other options...
  11. Sep 7, 2023 at 3:49 PM
    ExperiMentaltaco
    ExperiMentaltaco Active Member
    Josh
    2023 Tacoma TRD Off-Road
    The AnyTime Locker Install video is up!!!
    Visit
