Lock troubles!
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomagirl_09, May 4, 2009.
  1. May 4, 2009 at 3:44 PM
    tacomagirl_09
    tacomagirl_09 [OP] Member
    Utah
    '96 LX Toyota Tacoma
    4" Pro Comp Lift Kit, K&N Cold Air Intake, Powerade Throttle Body Spacer, Jardine Performance Exhaust, Tow Package, 8" MTX Subwoofer, Cut-out Bushwacker Fender Flares.
    My lock on the driver side of my 1996 Tacoma is broken. I can lock it from inside but I cannot unlock it with my key on the outside. I have to unlock the passenger side and crawl over to pull the lock up or I don't lock my doors at all which worries me. How much does a new lock cost? Also, do I order the part from Toyota or where would I go about buying one? I have looked at Ebay and all I have found is door handles that don't come with locks.
    Can anyone help me out? Thanks in advance! :p
  2. May 4, 2009 at 6:12 PM
    mhonda98
    mhonda98 Member
    Atlanta
    03 PreRunner Ltd TRD
    You might want to check to see if the rod that connects to the lock has come off. It should be held on with a plastic clip that might have broke. Just a thought. What happens when you turn the key in the lock?
  3. May 4, 2009 at 10:37 PM
    tacomagirl_09
    Utah
    The key turns but it doesn't unlock. :(
  4. May 4, 2009 at 10:40 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Sounds more like something is disconnected than broken. Take the door pannels off and snoop around!
  5. May 5, 2009 at 7:18 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    It's also possible for the connector to get bent over time until it doesn't release the latch.
  6. May 5, 2009 at 7:37 AM
    GA1044
    GA1044 Well-Known Member
    San Marcos, TX
    2002 trd 4x4
    Air Hog, Grey-Wire Mod, Fabtech Coilover 3.5 Lift, Deck Plate Mod, Rear Diff Breather Mod, Magnaflow Exhaust
    having a similar problem, except that my key wont rotate. I have to open my truck from the passenger side. any suggestions with this one
  7. May 5, 2009 at 10:16 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    my pass door lock fell into my door twice so far. so now i just use my keyless cause i dont want it to happen again. :rofl:
  8. May 5, 2009 at 10:41 AM
    mhonda98
    mhonda98 Member
    Atlanta
    Sounds like the rod has come loose or off. I would take the door panel off and look at the backside of the handle. There will be two rods one for the door handle itself and one for the lock.
