Lock/Unlock beeping
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoDrive, Mar 8, 2010.
  1. Mar 8, 2010 at 9:14 PM
    TacoDrive
    TacoDrive [OP] Member
    Oregon
    03 Double Cab 4x4 SR5
    Toyo 265/75R16 M55 tires, Raingaurds on all windows
    I have a 2003 Tacoma Double Cab. When I press lock, all the doors lock but it is accompanied by a single beep. When I press unlock once, the drivers door unlocks with two beeps. A second press of unlock does the rest of the doors with another two beeps. I would love it if there was a way to customize the beeping and the lock/unlock function. I would like to keep the single beep on when the doors are locked, but have the truck unlock all the doors at the same time with a single push of the unlock button, and only have two beeps with that. Also, if there is a way to have the beep turned down in volume, that would be amazing. I hope this isn't too much to ask from a new member here, but this is the only thing that is annoying me about my taco... Hopefully you can help!
  2. Mar 8, 2010 at 9:43 PM
    JayDub
    JayDub Well-Known Member
    Jay
    Pendleton, SC
    06 Tacoma DCSB 4x4
    Check here.. you can customize how your keyless entry works
    http://www.trdoffroad.com/articles/keyless/index.php
    As far as volume..the beep sound is emitted by a simple Piezo beeper, tucked in between the battery and the fender on the drivers side.. I guess you could manually adjust the volume by wrapping the speaker up in some more foam or something..but there's no way that i know of to electronically control the volume.
    Hope this helps!
    -Jay
  3. Mar 9, 2010 at 4:17 PM
    TacoDrive
    Oregon
    Thank you so much for that! I finally got around to doing it, I have been doing homework all day so it was nice to finally be able to go and do something that made sense and gave a satisfying result.
    For anyone else who is interested, this is what you do to have a single press of the "unlock" button unlock all the doors:
    1. Get in truck, close door
    2. Put key in ignition (I started the truck and turned it off, don't know if that changes anything)
    3. Open door
    4. Remove key from ignition
    5. Insert key into ignition twice (In, Out, In, Out)
    6. Close the door twice (Close, Open, Close, Open)
    7. Insert key in and out of ignition once (In, Out)
    8. Close the door twice (Close, Open, Close, Open)
    9. Insert key into ignition but do not remove it
    10. Close the door
    11. Turn the key from lock to on 4 Times (Lock, On, Lock, On, Lock, On, Lock, On)
    12. Remove the key from ignition
    At this point the locks will lock and unlock a number of times. Wait until they stop then
    13. Press and release both the "lock" and "unlock" buttons simultaneously
    14. Press and release the "unlock" button
    15. Open the door
    Now check to see if a single press of "unlock" will unlock all the doors. If not, try again. I had to do this twice for it to work for me.
    For the volume, I put some duct tape over the beeper and put a whole in the top, widening it until the volume was where I wanted it. I may remove this later if I get insecure about whether I am actually locking my doors.
    Thank you again Jay W. for your help and I hope this helps anyone else interested in the same thing
  4. Mar 9, 2010 at 4:29 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    To turn down the beep, just cover the hole on the piezo alarm with electrical tape. The piezo alarm is located just behind your battery. That's what I did. You can still hear it but it's not so loud now.:D
  5. Mar 9, 2010 at 7:32 PM
    TacoDrive
    Oregon
    Yeah thats what I did, just with some duct tape ha it was handier and more easily available for me at the moment.
  6. Mar 10, 2010 at 6:54 AM
    mjhenks
    mjhenks Well-Known Member
    So.Cal
    04 Jade Green TRD V6 DC
    Thaks for the post. The lock/unlock sound is a bit loud to me to. I also like changing the unlock function but man if i did not know better i would say April Fools. Quite the dance. Will give it a try with my 04 DC..
  7. Mar 10, 2010 at 7:26 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Im def. ganna try this on my truck! thanks for the post.
    I hate pressing the unlock twice to open all the doors, and hearing 4 loud beeps. uuughh..... :)
  8. Mar 10, 2010 at 8:13 AM
    slickyd
    slickyd Well-Known Member
    David
    Talladega, AL
    03 PreRunner SR5
    Finally did it yesterday and I love it. Now to put some tape over that stupid buzzer.
  9. Mar 10, 2010 at 4:13 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    ok well I did it last night and now I cant get my truck to start. stupid killswitch thing wont deactivate.......
  10. Mar 10, 2010 at 5:52 PM
    ETaco23
    Evan
    PNW
    wow! just did it and its freaken awsome! thanks for an awsome mod! I only had to do it once, and it worked perfectly. :)
  11. Mar 10, 2010 at 7:12 PM
    monoman
    Dave
    ....now, if you don't want to hear the "chirp" at all, just unplug the piezo alarm. It has a connector that you can disconnect.:thumbsup:
  12. Mar 11, 2010 at 1:45 AM
    dustinuhls
    dustinuhls Well-Known Member
    Manhattan, KS
    2015 TRD Sport 4wd
    Icon Coilovers, Magnaflow, K&N Intake
    Not sure how your truck's alarm/keyless works, but on my '01 Tacoma, pressing the button once locks and unlocks the doors, but if you hold the button down (when unlocking) unlocks all the doors. If you press it quickly, it just unlocks the drivers door. Hold it down and it should unlock all the doors...
  13. Mar 11, 2010 at 3:12 AM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    Who had time to figure this one out? I can just see some guy out in the garage late at night, slamming his door repeatedly, while his wife is yelling to come in.
    "Just a minute, honey! I've almost got this!":D
  14. Mar 11, 2010 at 3:21 AM
    kanelakos
    kanelakos Well-Known Member
    Binghamton, NY
    16 DC LB Sport
    LOL! No shit!:D My issue is I had a remote start put in. Now the horn beeps with lock/unlock and is alot louder than original beep. I will probably have to go back to the business that installed it and see if they can do something about it. I would love to go back to just the "quiet" beep.:rolleyes: (leaving remote start installed of course).
  15. Mar 11, 2010 at 3:30 AM
    dustinuhls
    Manhattan, KS
    2015 TRD Sport 4wd
    Is the "volume" of your beep really that big of deal???
  16. Mar 11, 2010 at 4:00 AM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    I tried holding down the unlock button to unlock all doors and it didn't work on my 03 dbl cab.
  17. Mar 11, 2010 at 7:52 AM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    Didn't you already reprogram it?
  18. Mar 11, 2010 at 8:17 PM
    747
    747 function > form
    1st Gen.
    This is an old post, but includes the option of adding "ignition-engaged door lock function"...I don't remember where I found the instructions (but I wasn't the guy in his garage f'ing around with the door...see previous posts:D): http://www.tacomaworld.com/forum/1s...ntry-ignition-engaged-door-lock-function.html
  19. Mar 11, 2010 at 8:26 PM
    TacoDrive
    Oregon
    Wow I'm so glad to see that my first post here got so much attention! I hope this is working out for everyone!
  20. Mar 11, 2010 at 8:52 PM
    SURFTACO
    SURFTACO Well-Known Member
    New Jersey
    09 TRD SPORT
    3'' Lift: Bilstein 5100’s, SPC UCAs, All Pro 3” leaf packs, Bilstein 5125’s, Kenda 33X10.5R17 Tires Flat Black Stock Rims Seat Belt Chime off Fog Lights On anytime Jet pilot interior All weather floor Mats Tonneau Cover Cali Raised Ditch Lights Snorkel
    Will this work for a newer Tacoma, 2009 maybe?
