LOCK/UNLOCK Chirp for DTRL and Alternating turn signal modders
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FlawedXJ, Apr 3, 2009.
  1. May 15, 2009 at 7:49 PM
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    This looks like a great idea! What gage of wire should I use to wire up the buzzer? Looks like your using 14ga maybe?
  2. May 15, 2009 at 7:54 PM
    FlawedXJ
    FlawedXJ [OP] mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    any guage is good as long as its 12-18. Mine is 14 and was kinda over kill. The wire will not bear a big load considering it will just be a very small amount of voltage applied to it.
  3. May 15, 2009 at 7:57 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    is that what you put in my truck?
  4. May 15, 2009 at 7:58 PM
    FlawedXJ
    Paul
    NorAla
    i think so. I typically just use speaker wire cause its cheaper and has never let me down. If its something bigger i wip out the better wire.
  5. May 15, 2009 at 8:00 PM
    MattN03
    Bluegrass State
    Thanks. Also, which one of these Radio Shack buzzers did you use? Do you have a part number by chance
  6. May 15, 2009 at 8:02 PM
    FlawedXJ
    Paul
    NorAla
    gosh, i did at the time. I threw it away. Its the 3-28v piezo buzzer (non pulsing). It's about 6 quarters thick with a little quarter sized recess on the bottom of it.
  7. May 15, 2009 at 8:04 PM
    Lentsnh
  8. May 15, 2009 at 8:05 PM
    Lentsnh
    You used the blue wire. I think you said it was from your back up camera :confused:
  9. May 15, 2009 at 8:39 PM
    FlawedXJ
    Paul
    NorAla
    nope. speaker wire. back up camera wire has like 4 cables in it, including a video wire.
  10. Jun 8, 2009 at 10:52 PM
    peleus21
    peleus21 Well-Known Member
    okanogan, b.c. canada
    red trd sport
    led taillights HID dual beam headlights bolts and clamps to handle off road
    hooking up to the wireless receiver would work because the receiver only locks the door if the key is not in the ignition. i hooked mine up with a reverse relay(donno what they are called) to the door lock positive(to relay input) key indicator wire (coil ground) 12+ (coil pos) relay output to peizo and ground it to frame there. this makes it only beep when key is not in the ignition it does not beep for door unlock anytime or for door lock when running
  11. Jun 9, 2009 at 6:54 AM
    FlawedXJ
    Paul
    NorAla
    post up pics man.
  12. Jun 9, 2009 at 8:59 AM
    peleus21
    red trd sport
    will post pics and a write up in next day or so.
  13. Jun 9, 2009 at 4:58 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    Anyone know how to allow the truck to be locked even when the doors are ajar and/or the key is in the ignition....i'm not that familiar with the wiring but In cold mornings in Idaho it is nice to warm up the truck in the mornings and since i have another set of keys its nice to not have your truck out there running while unlocked. Also i would like to be able to lock my doors and then grab an arm load of crap from the truck and shut the door rather than having to keep my keys out and fumble around with them while i have stuff in my arms just to lock it.
  14. Jun 9, 2009 at 6:34 PM
    peleus21
    red trd sport
    this shouldn't effect any of that all this is, is to make it so when u get out of your truck at night and lock the doors, it chirps to let u know. it does not effect other systems.
  15. Jun 9, 2009 at 6:35 PM
    #35
    peleus21
    red trd sport
    as for running on a cold morning i hear ya it get up to -40 where i live. why not get a remote starter and alarm system
  16. Jun 9, 2009 at 7:01 PM
    #36
    gjbonner
    Guy
    Northern Idaho
    Thatd be nice yes but friday i am pumping a lot o cash into the truck. 6" fabtech lift, crawler wheels, and 305/70/16 general grabber AT2s so thats just another chunk of change when, if possible, i could just mess with the wiring and make it to where it locks for me whenever i want it to...and just to clear it up i actually have done this mod but thought maybe these guys would know how to do the part i was asking about.
    How much does a remote start cost for us anyways...any referrals? also inexpensive alarms?
  17. Jun 9, 2009 at 7:15 PM
    #37
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Good luck with a remote start since it's a manual.... Most of the shops I talked to around here either wouldn't do remote starts on manuals, gave me the run around, or had crazy expensive or annoying systems.
    As in, systems that require you to prime EVERY time you get out if you want to use them. Prime as in push the remote start, turn the key off, get out, lock the doors, and turn off with remote start. Then if ANY of the doors open the system shuts down and you can't remote start until it's primed again. :rolleyes: I can understand it from a liability standpoint. No one wants to be responsible for some jackass remote starting his truck through someone's house, but come on! If I had a system like that I know I'd stop using it within a couple weeks. Between random trips to the truck for forgotten things, tools I carry in it all the time, and the wife running to the gas station for smokes it would never stay primed.
    If someone knows of a more.....convenient system I'd love to know about it.
    curtc101 likes this.
  18. Jun 9, 2009 at 7:27 PM
    #38
    gjbonner
    Guy
    Northern Idaho
    LMAO it had to happen once, you know it!
    I hear ya. i wondered how that might work...i can see how there would be way to much liability and what is out there sounds like its not worth it.
    any ideas on the lock doors "whenever you want to" thing i was talking about?
  19. Jun 9, 2009 at 7:35 PM
    #39
    piercedtiger
    Jon
    Southern Tier, NY
    not offhand... I hit the auto lock button when I get out to lock the doors when they're open. I know that doesn't work with keys in the ignition, but I never leave mine in there. I wanna say the keyless entry shuts down with a key in the ignition too, but I haven't tried that in a while.... I think you'd have to bypass a few things or do an aftermarket alarm (probably the easiest way) since it kills the factory remote, and unlocks even if you do it manually with a door open and keys in.
  20. Jun 9, 2009 at 9:04 PM
    #40
    peleus21
    red trd sport
    bunch of tests yesterday
    here is what works and does not on the remote (when keys in the ignition it is regardless the position)
    keys in the ignition:
    doors unlock
    keys out of ignition:
    doors unlock and doors lock
