Lock up confusion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GrebTacoma, Aug 18, 2021.
  1. Aug 18, 2021 at 6:06 PM
    GrebTacoma
    GrebTacoma [OP] Active Member
    Greg
    2018 TRD Sport 4x4 DCLB
    I am using OBD Fusion and have purchased the Tacoma add-ons. I have "lock up status" added and see it in 4 sport mode but am also seeing it in 5 and 6 in drive mode. I am confused about the 5 and 6 gear lock up. From my understanding, that is not possible. Ant thoughts?
  2. Aug 18, 2021 at 6:11 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    What the hell are you talking about? Doors? Tires? ABS? Torque converter? Gotta do a better job at splaining there Ricky.
  3. Aug 18, 2021 at 6:14 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Does the software purchase not come with tech support?
    grandpawmoses and Junkhead like this.
  4. Aug 18, 2021 at 6:19 PM
    mhornco
    mhornco Well-Known Member
    I believe that is torque converter. It will unlock or lock depending on load on any gear. Think it is a zero or 1
    Junkhead, GrebTacoma[OP] and Skydvrr like this.
  5. Aug 18, 2021 at 6:22 PM
    GrebTacoma
    Greg
    Torque converter. Never heard of lock up status for doors, tires, or abs. But I obviously don't know as much as you do.
  6. Aug 18, 2021 at 6:23 PM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    Sounds like you are talking about the torque converter lock up status. It locks up in any gear but not when you are accelerating and decelerating a lot, conditions like city driving. Higher constant speeds like when you get into 4, 5, 6 gear it is pretty quick to try to lock up the torque converter for efficiency.
  7. Aug 18, 2021 at 6:23 PM
    squamishdroc
    squamishdroc Well-Known Member
    Powell Riveria
    2021 Off Road Premium in AG
    5100's and Cooper 265/75/16's
    Torque converters will lock up whenever the computer wants them to - my Grand Cherokee can lockup in any gear.
    GrebTacoma[OP] likes this.
  8. Aug 18, 2021 at 6:26 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    @Vlady has stared at TQ status a bunch I believe
    Junkhead likes this.
  9. Aug 18, 2021 at 6:28 PM
    GrebTacoma
    Greg
    Thanks for that reply. So you get the benefit of lower transmission temps when locked up in 5 and 6? I was under the evidently mistakes impression that it would only lock up in 4th at 1:1. Must be something else going on in there I don't know about or understand. Thanks again.
  10. Aug 18, 2021 at 6:33 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Here's the full lockup schedule; you need to be in S3 to deactivate it.
    Here is the flex lockup(slip control) schedule.
    mosccat, ktbell444, Junkhead and 4 others like this.
  11. Aug 18, 2021 at 6:39 PM
    splitbolt
    NW Arkansas
    I think it might be what you think the 1:1 actually is.
    It's, engine output rpm :transmission input rpm
    The gears don't give a shit how fast the input shaft is/isn't spinning.
  12. Aug 18, 2021 at 6:40 PM
    flatus
    flatus Well-Known Member
    biloxi,ms
    2020 TRD OR DCSB 4wd Auto
    Waiting for bank account to grow
    Put the transmission in "D" and press the gas pedal. The truck will move forward. This is really all that matters.
    Junkhead and Abject4x4 like this.
  13. Aug 18, 2021 at 6:43 PM
    GrebTacoma
    Greg
    Sounds like good advice if you are towing.
    mosccat likes this.
  14. Aug 18, 2021 at 6:47 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Do u use the S mode towing?
    (Not sarcasm)
  15. Aug 18, 2021 at 6:51 PM
    GrebTacoma
    Greg
    Manual suggests sport mode 4th gear when towing. So yes. I was under the impression that would keep it ( at speed) locked up for lower transmission temps. Just confused about the apparent ability to lock up in 5th and 6th. Maybe can't hold it when towing? That is the crux of my question.
    boston23[QUOTED] likes this.
  16. Aug 18, 2021 at 6:57 PM
    ForceOfG
    ForceOfG Well-Known Member
    Portland, OR
    16' DCLB 4x4 Off-Road
    5.29 Yukons Stage 2 Icons 265/70/17 OVTuned
    I dont know if this is just untrue or doesn't apply to all vehicles but I do know for sure that on the 16's and 17's the TC stays locked in 6th no matter what once you're above about 1250 RPM in that gear, if you could lock in 6th it would never unlock above 53MPH/1250 RPM. 5th gear is actually set to lock at a higher speed than 5th and also wont unlock once its above 58 MPH. Also with the stock logic they do not lock in 3rd gear at all. Only part lock.
    mosccat and GrebTacoma[OP] like this.
  17. Aug 18, 2021 at 7:03 PM
    splitbolt
    NW Arkansas
    Just to clarify, D or S mode?
  18. Aug 18, 2021 at 7:26 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Calibration matters too
  19. Aug 18, 2021 at 7:37 PM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    torque converter....it's pretty obvious
    JettShepard and GrebTacoma[OP] like this.
  20. Aug 18, 2021 at 8:02 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Nope. That requires you to assume and you know what that means....
