Locked emergency brake in cold weather...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by powdr_dayz, Oct 26, 2011.
  1. Oct 26, 2011 at 4:11 PM
    powdr_dayz
    powdr_dayz [OP] Active Member
    Colton
    Montana
    2010 Tacoma TRD Off Road
    It has happened to my truck the last two mornings. Temps got down to ~25 degrees (F), and the drivers side rear wheel completely locked up...Just wondering how many people have experienced this...The local dealer said that I just shouldn't use my E-brake in the winter...WTF?
  2. Oct 26, 2011 at 4:22 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    yes it happens. it has happened with all my cars that i used the e-brake on when i had manual trans cars. my brother WRX has the same issue
  3. Oct 26, 2011 at 4:22 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Arlington, Virginia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Did you wash your truck recently?
  4. Oct 26, 2011 at 4:24 PM
    Hard
    Hard Well-Known Member
    H
    4X4X4
    There is water getting in your system and freezing. I have had frozen brakes before, and I avoid using my e-brake when I think it might freeze. Is there snow? It could be from rain then freezing over night.
  5. Oct 26, 2011 at 4:30 PM
    ruslanus
    ruslanus Well-Known Member
    Rus
    Wasilla, AK
    It has never happened to me, but then again, I know about the freezing so I never use e-brake when there is a possibility of freezing temps. Just like people raise the windshield wipers so they won't freeze to the windshield (unless your vehicle is equipped with a windshield defroster).
  6. Oct 26, 2011 at 4:31 PM
    NFK
    NFK Death Technician
    Nick
    Canada, BC, Vancouver Island, Victoria
    BLACK THUNDER
    Tiers 33/11.5 tiers Mickey Thompson,Wheels Mickey T Side Bitters 17” 3” Rev Tech Lift,Added Leaf Spring,Black Projector Headlights CCFL Halo’s / HID’S Blacked out tail light Mod,Grill craft Grill Top and Bottom Hella 500 Behind Gril,FJ40 1986 Toyota Land Cruiser Emblem Front Grill K&N Air Filter,TRD Emblem Lower Grill Bottom Right,Toyota Bug & Stone Deflector Toyota Skid Plate Rhino Lined,WeatherTech Window Visors AVID Step Up Sliders,Bushwhacker Pocket Style Fender Flares Key Hole Plugs Colour Matching,Tacoma Bed MattRear,Tailgate Anti-Theft Mod ( Key Hose Clamp) Leer 100XQ Canopy,Semi De-BadgedPainted Remaining Badges (black) FA-series Short Stubby Antenna Length: 8" TRex Eyelids,Wet Okole TRD Seat Covers Charcoal And Black With Center Console And Rear Pockets With TRD Emblem logo WeatherTech Floor Mats,48 LED Blue Dome Light
    happind to me bad!!!! right befor work! its was -53 cel ! i fuckin nearly shit my pants i was going to be late! never let that hapin again!
  7. Oct 26, 2011 at 4:34 PM
    curtsmith17
    curtsmith17 Active Member
    SMITTY
    ON
    09 4x4
    Bilies 5100 All Four Corners (O.85" in Front), Eibach/Toytech Springs, URD Short Shifter
    moisture on brake pads freeze to rotors/drums. Keep it in 1st no e-brake around freezing temps or when truck has been wet in freezing temps. :D
    I live in Canada!!!
  8. Oct 26, 2011 at 4:53 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    Unless i park on a hill I have never used the parking brake to park.
    Winter time is a PITA. You never know if that slush puddle you went through will cause an issue.
    If you have to use it, then use it. But if you don't have to don't.....
