Locked keys in 3rd gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kystnTRD, Mar 15, 2019.
  1. Mar 15, 2019 at 7:46 AM
    #41
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    It's been almost 3 years since I made the change, but I believe the settings are located in the somewhere in the radio.
    Mine was setup to NOT auto-lock when I first got the truck. Ironically, I enabled auto-lock since I had a instance a few years back where I was carry a heavy box up he stairs, said box depressed key in my pocket and I did not realise, and a few hours later someone stole about 2 grand worth of equipment from my car.. FWIW, you can not lock your keys in the truck with the auto-lock feature. Although it may be a bit of an inconvenience for some.
  2. Mar 15, 2019 at 7:47 AM
    #42
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    Shipping company locked my keys in the truck that way in 2016 and ripped the vinyl between the windows and dented the inside of the door when they tried to unlock it. Truck had less than 2,000 miles on it before it had its first repair :rolleyes:
  3. Mar 15, 2019 at 7:48 AM
    #43
    SC4333
    Grant
    FL
    An inflatable door wedge from home depot or Lowes along with a coat hanger should work. They are relatively inexpensive. Pull on the upper corner of the door, shove the bag in, give it a few pumps where you can get a hanger or rod in, and then hit the unlock button.
    shakerhood likes this.
  4. Mar 15, 2019 at 7:52 AM
    #44
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    How much do you want to “break” your truck? Best to call professional to unlock, will be least PITA and less potential damage. One note of entry no one has articulated yet, IF you have a pop-n-lock installed. All you’ll need is a 9v square type battery, cut the wires running to the pax door in an area easy to access and later repair. Attach wires (to vehicle entrance side, not to PnL side) to 9v battery and voila... doors unlock.
    Example; however power to the vehicle wires... will power up the door actuator instead of PnL:
    https://m.youtube.com/watch?v=QpnFEbEDHSk
  5. Mar 15, 2019 at 7:59 AM
    #45
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Get a soft top Wrangler, very easy to get in with out a key.
    Toyoduhh likes this.
  6. Mar 15, 2019 at 8:02 AM
    #46
    Wasatchrider
    Wasatchrider Well-Known Member
    get someone who has access to your spare keys call them on the phone and have them push the unlock button. It works Ive done it.
    Crimson Flam3s likes this.
  7. Mar 15, 2019 at 8:08 AM
    #47
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
  8. Mar 15, 2019 at 8:15 AM
    #48
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Have them run by Walmart for a fresh battery for the fob first. You need a good strong signal, and preferably a land line.
  9. Mar 15, 2019 at 8:22 AM
    #49
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    The lock switch becomes disabled when the BCM shuts down. Meaning even if you wedge the door and are able to get a coat hanger in there pressing the switch won’t do anything. You’ll have to try and hit the unlock on the keys of accessible or manually force the lock mechanism to the unlock position and then pull the handle open. The rods the lock Smith’s have are strong enough to do the job but can still take someone with experience upwards of a half an hour to be able to get in. And there is always some risk of damaging some paint or seals around the door.
  10. Mar 15, 2019 at 8:50 AM
    #50
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    See if AAA will let you sign up over the phone and send someone out. I used to lock myself out all the time with my first car, AAA was great about getting me sorted quickly.
  11. Mar 15, 2019 at 8:56 AM
    #51
    Sgt.Tee
    Sgt.Tee Well-Known Member
    Pete
    NE Pa
    2019 MGM SR Tacoma 4&4
    Ok this idea will not work for you I have the flat key.
  12. Mar 15, 2019 at 9:00 AM
    #52
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
  13. Mar 15, 2019 at 9:02 AM
    #53
    Sgt.Tee
    Pete
    NE Pa
    Call someone and a lesson learned
  14. Mar 15, 2019 at 9:07 AM
    #54
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    No, it won’t. If no door is opened it’ll auto lock
  15. Mar 15, 2019 at 9:32 AM
    #55
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
    2018 Blazing Blue Pearl SR5 DCSB
    I have State Farm. It covers someone coming out to unlock your truck. Had it done a couple of times thru the years
  16. Mar 15, 2019 at 9:41 AM
    #56
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    I have a non cool key and the truck will lock with the key inside as long as it's not in the ignition switch. I had a non chip key made for my wallet...just in case.
    Boghog1, 1taco2motos and Sgt.Tee like this.
  17. Mar 15, 2019 at 9:47 AM
    #57
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    I keep mine in the garage unlocked so I didn't know the truck had that feature . I just checked mine and it re locks in 60 seconds .
  18. Mar 15, 2019 at 9:54 AM
    #58
    gerbil
    gerbil Meowface McWhiskers
    Belmont, NH
    2019 SR DCSB 4wd v6 silver
    I’m sure the guy is in his truck by now. Sorry for your situation - it’s no fun at all. And I’m sure he’s already got a million solutions planned for next time.
    But I do want to recommend the hitch safe or hitch vault or whatever brand someone else mentioned. I put one in my hitch almost right away upon buying the truck. It’s a combination-locked compartment specifically for hiding things like a spare key. The one I bought from Amazon (had to buy the longer pins too) is really high quality and I’d recommend it for sure.
    FLA_Hoosier likes this.
  19. Mar 15, 2019 at 1:54 PM
    #59
    cwdog
    cwdog Well-Known Member
    Asheville, NC
    2017 Tacoma Limited
    Meguiars Ultimate Wax, Rain-X, Dog Bed, Undercover Tonneau Tri-Fold, Debadged.
    I understand, it's only money.
  20. Mar 15, 2019 at 3:36 PM
    #60
    Sgt.Tee
    Pete
    NE Pa
    Is this the one??????????
    HitchSafe HS7000 Key Vault.. I bought a aftermarket hitch
