Locked keys in truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Big Sky Country, Apr 30, 2018.
  1. Apr 30, 2018 at 5:09 AM
    Big Sky Country
    Big Sky Country [OP] Well-Known Member
    Montana
    2013 DCSB TX Pro
    Century topper, OME 885x, Nitrochargers, full Dakars
    We were at the lake this last weekend and I left my keys in the truck. When I was coming outside to leave, I heard the lock beep and realized the truck had somehow locked itself. Standing there looking through the window at my keys in the cupholder, it continued to cycle the door locks (unfortunately never to unlock), lights flashing and everything. This went on for at least 45 minutes until I was able to fish the keys through a tiny opening in the drivers side window using a coat hanger. Everything appears fine now but it was weird as hell. Thoughts?
    I drive a '13 DCSB TX Pro.
  2. Apr 30, 2018 at 5:15 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I've noticed that if I unlock my truck (2014) with the key fob that the truck locks after about 30 seconds if I don't open any of the doors. You would think that there would be some kind of sensor in the fob so the truck doesn't lock if the keys are inside of the truck.
    Biscuits and TacoCat like this.
  3. Apr 30, 2018 at 5:20 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    How about not leaving the keys in the truck? Or you could go get a 1 dollar copy of the key made to keep in your wallet or hide under the truck somewhere just to unlock the door
  4. Apr 30, 2018 at 5:21 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Hide a spare somewhere...
    Bebop likes this.
  5. Apr 30, 2018 at 6:05 AM
    Jonah
    Jonah Well-Known Member
    Joe
    Charleston, SC
    2014 TRD O/R 4x4
    First thing I do with every vehicle I've ever owned.
  6. Apr 30, 2018 at 6:14 AM
    dlawrence529
    dlawrence529 Well-Known Member
    Maine
    2015 MGM Double Cab Long Bed
    I had this happen to me. It's a "safety feature". You have to make sure you use the door panel to unlock your door if you don't want it to re-lock. You can't use the key fob.
    I have to leave keys in my car so it can be moved on construction sites. I now leave them in the gas cap.
  7. Apr 30, 2018 at 6:36 AM
    Big Sky Country
    Montana
    2013 DCSB TX Pro
    Our '12 4 runner will not lock with fob inside, just beeps like crazy until you open the door.
  8. Apr 30, 2018 at 6:38 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
  9. Apr 30, 2018 at 6:43 AM
    Big Sky Country
    Montana
    2013 DCSB TX Pro
    Thanks, this was the answer is was looking for. Wanted to make sure there wasn't something else going on, it was like the truck was possessed! For some reason I didn't think it was possible to lock the keys inside, the the 4-runner.
    dlawrence529[QUOTED] likes this.
  10. Apr 30, 2018 at 7:22 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    When I’m home I always leave my keys in the truck (ignition). I’ve never had this happen to me.
    Sounds odd. I know the doors relock if you don’t open the doors within so many seconds of unlocking them with the fob.
    I’m thinking the truck is haunted. Sounds odd.
    Was there anything resting on the keys so maybe the button was getting pushed?
  11. Apr 30, 2018 at 7:23 AM
    Bebop
    Nick
    A truck with the keys in it? What’s your address? :rofl:
  12. Apr 30, 2018 at 8:12 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Same here, my wife's car also has a hidden key since about 2 times a year she locks her keys in her car,saves me having too go get her everytime.
  13. Apr 30, 2018 at 8:38 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Yup, its a safety feature, if you unlock the doors with the keyfob but do not open a door, it will relock in 30seconds.
    You can not lock the doors with the keys in the ignition and the truck off they will instantly unlock.
    But yes, go get a standard metal key copied and hide it somewhere on the truck. This will get you in the door (but not be able to start the truck). I have a hidden standard metal key on my truck, then my second chipped key is hidden very well within the cab of the truck so in the event i fully loose my keys i can still get home.
    spitdog likes this.
  14. Apr 30, 2018 at 9:22 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Use the Force.
    Hagstromez and Bebop like this.
  15. Apr 30, 2018 at 10:56 AM
    Big Sky Country
    Montana
    2013 DCSB TX Pro
    I never locked the truck when I got out. Threw keys in cupholder and ran inside to change, took maybe ten minutes. As I'm walking down the stairs, I heard the truck beep and went "oh shit". Was certain someone was messing with me.
    I know I've been in this same scenario before and it's never happened. I do it all the time in my driveway if I running inside for a few minutes.
    I know there was nothing resting on them because I could see them.
  16. Apr 30, 2018 at 11:05 AM
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    I had hit my door panel lock and as soon as I shut my door, I realized the keys were in the cupholder. Had to get the little airbag and long wire to push the unlock button. It took a couple of hours all total. Went to locksmith and had door lock only key made and hide it on the truck where I can get to it. On all my old trucks 60's thru 90's ALWAYS had coat hanger under the bed mat as I had a bad habit of leaving keys in the truck.
  17. Apr 30, 2018 at 11:05 AM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    TacomaMike37[QUOTED] likes this.
  18. May 1, 2018 at 8:52 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I worry about doing the same thing. The key fob for my '09 is separate from the key, so I keep it attached to a separate key ring so i have a way to unlock the door if the key is locked inside.
  19. May 1, 2018 at 8:57 AM
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    I locked mine a while back. A note for those in the future, a slim Jim doesn't work in out trucks. Also, some say they can pry and slide the back sliding window, but mine wouldn't slide open. Airbag and rod popped the lock.
    Also, I went and had a key made at ACE hardware. He said he couldn't get one with a chip because it's some sort of super chip he can't replicate. However, my dummy plain metal key starts the ignition fine. Idk if it is because I have a base model or what...
  20. Nov 12, 2021 at 7:46 PM
    Coolio
    Coolio Member
    2021 Tacoma SR5
