Locked Off-Road Bumpstops and Pricing
Discussion in 'Locked Off-Road' started by TacomaGuy23, Aug 18, 2017.
  1. Aug 18, 2017 at 11:29 AM
    TacomaGuy23
    TacomaGuy23 [OP] Well-Known Member
    Cody
    Fullerton, California
    2014 Tacoma Double Cab Prerunner
    Dirt King Long Travel, URD Supercharged
    http://locked-off-road3.mybigcommerce.com
    15% OFF FOR TACOMAWORLD USERS!
    Contact: (951) 852-7392 (Riley) or
    (714) 931-0420 (Cody)
    Email: Getlockedoffroad@gmail.com
    Instagram:
    https://www.instagram.com/locked_offroad/?hl=en
    PM me directly for any purchase inquiries or any questions!
    Locked Off-Road is a southern California based company, located in Temecula, that specializes in high quality bumpstops.
    We live life off-road and in the process of building out our own trucks, we scoured store after store worldwide to find the best possible deal on the highest quality off-road parts.
    Our goal is to provide higher quality bumpstops made from superior materials at a lower price point. We're not trying to be millionaires and we're not trying to get as much as possible for a standard product. We just want to build bad-ass trucks and see our bumpstops on yours. We GUARANTEE our bumpstops 100% and if there is ANY issue with quality we will refund or replace them for FREE.
    Bumpstop Pricing
    2" Pin Style + Mounting Sleeves: $360
    2" Pinch Style + Mounting Sleeves: $360
    4" Pin Style + Mounting Sleeves: $380
    4" Pinch Style + Mounting Sleeves: $380
    Info About 2" Style:
    • 2.0” diameter body
    • 2” or 4" stroke length
    • Large 1-1/4” diameter shafts are hard-chromed, preventing rusting and essentially creating a self-cleaning system. Shafts are also polished to a mirror-like finish, ensuring extended seal life
    • Schrader cap mounts directly to the body of the bump stop, not the valve, creating a stronger seal, keeping everything clean and dry by keeping out dirt and moisture
    • O-ring on shaft gauges your travel
    • Bump stop bodies are made from 4130 Chromoly providing the advantages of high tensile strength and malleability. Stronger and more durable than standard 1020 steel
    • Secure indexing pin prohibits the outside of the tube from pinching
    • Delrin contact pad is mounted with a single flush mount design, protecting your suspension and insuring quiet operation, with no metal on metal contact
    Pin-Style Mounting Sleeves Feature:
    • Heavy-duty mounting sleeves come ready to weld
    • Pin-style cans hold the bump stop around the entire diameter, providing 360° coverage without any pinching like traditional pinch-style cans
    • Sleeves built to allow room for shrinkage during the welding process
    • Indexing holes are laser cut and keep bump stop securely in place within the can
    Side-Pinch Mounting Sleeves Feature:
    • Traditional, side-pinch mounting sleeves
    • Sleeves built to allow room for bump stop expansion
    Info About 4" Style:
    • 4.0” diameter body
    We look forward to representing ourselves amongst such a wonderful community!
    ninja89, Dan4589 and mcharfauros like this.
  2. Aug 18, 2017 at 11:32 AM
    TacomaGuy23
    Cody
    @MaxxTRD Review of Locked-OffRoad during our group buy
    Hey guys! My name is Maxx.
    Just thought i should step in and try to clear up some of the skepticism!
    A few months ago i picked up a set of these 2 inch pin style bump stops from Locked off Road. I too was a bit skeptical because at the time, i only wanted King Suspension on my rig. I had a set of King Bump Stops sitting in my online shopping cart but was reluctant to buy due to the high price tag. Thats when i found Locked Off Road on Instagram of all places. After looking through pics of their work and seeing some of the bad ass builds that were already using their gear i thought i would drop them a message and ask some questions about fitment, quality, size, ect. The Owner Riley got right back to me and walked me through all of my questions. Based on his awesome customer service and their 100% guarantee on quality, I decided to give it shot and ordered a pair of 2 inch bump stops.
    There was little to no wait time on my order and i had the bumps within a week or so. They came with heavy duty sleeves ready to be welded and the bump stops and the hardware seemed to be that of the same quality as my all my King Products.
    Instal took very litlle time at all. I have a fellow Firefighter buddy who does some basic welding on side projects and asked for his help in exchange for some beer and we struck a deal. we started by chopping off the stock bump stop. i chose to mount it in this location because it lined up with my Baja Kits Lower Control arm that has a reinforced plate designed to be used in conjunction with bump stops as does a stock lower control arm. After making room for the bumps we welded the sleeves directly to the frame. Afterwards we added small steel triangles for added support. This may not look the cleanest but it is functional, sturdy and works wonders.
    Now for performance. Couldnt be happier. If i could give the Five Stars i would. My wife and i took the truck to the Moses Lake Sand Dunes in Washington state before and after installing the bump stops and my wife even mentioned how much softer the suspension felt. She was actually able to relax and enjoy the ride! We tested the truck on the exact same whoop section. Before installing the bump stops the truck would start off ok but after hitting a few large whoops the truck would begin to buck up and down eventually bottoming out to the point where i would have to stop. now with the bump stops , hitting the same section the front end floats right over, there is no harsh bottoming out and the ride is enjoyable. Now im just waiting to get some for the rear end.
    In conclusion. I'm totally satisfied and will be buying a set for the rear. They have held up to thousands of miles of abuse and show no wear at all and continue to work flawlessly.
    I seriously hope im able to put you guys at ease because If you go with King, Icon, or Fox your literally just paying more for the name and the sticker and probably wont get the customer service or guarantee along with it.
    Ive attached some pictures of my truck and the bump stops. As well as the truck and bump stops working together in perfect harmony.
    mcharfauros and Spintly like this.
  3. Aug 18, 2017 at 11:36 AM
    TacomaGuy23
    Cody
    @ninja89 walk around review of Locked Off-Road Bumpstops
    ninja89 likes this.
  4. Aug 18, 2017 at 10:22 PM
    ninja89
    ninja89 HUH?
  5. Aug 23, 2017 at 11:17 AM
    TacomaGuy23
    Cody
    This is pretty cool. One of our old customers submitted a photo to us. He's running our first gen bumpstops on his tundra race truck!
    mcharfauros and ninja89 like this.
  6. Feb 27, 2018 at 10:00 AM
    Sosa34R
    Sosa34R New Member
    @TacomaGuy23 I got myself a pair of 2.0 last sunday at Soboba Off road Swap Meet. Can't wait to install these bad boys on my daily...
    TacomaGuy23[OP] likes this.
  7. Feb 27, 2018 at 10:06 AM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    So school me on these piston-looking bumpstops. I imagine they are much more comfortable than something like wheelers superbumps? Would something like this be overkill for a daily/offroad once a month truck?
    I think they look freaking awesome, but require extra work vs. the wheelers that are just a 'bolt-on' replacement. Worth it in your opinion?
  8. Feb 27, 2018 at 10:13 AM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Do you ever feel yourself hitting ypur stock hard rubber stops? If never then no these aren't for you. Wheelers works for 99% people wanting an upgrade.
  9. Feb 27, 2018 at 10:25 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Yeah I feel that all the time because I'm not exactly the.... *slowest* guy on the trail, especially in mud holes or shallow drops lol
  10. Feb 28, 2018 at 10:08 AM
    TacomaGuy23
    Cody
    You wont be disappointed !
    Pm me. we can chat!
    mcharfauros likes this.
  11. May 10, 2018 at 10:19 AM
    TacomaGuy23
    Cody
    We now offer a TacomaWorld Exclusive discount on every purchase. From here on out, TacomaWorld Users get 10% off of every purchase. If you have interest in placing an order from us, direct message me and I will provide the discount code!
  12. Oct 31, 2018 at 3:23 PM
    TacomaGuy23
    Cody
    Bumping this. Locked Off-Road is now offering 15% off of all products, instead of 10%. PM me if you would like to place an order and I can provide you with a code to use on our website.
    m00seNUckLEz and mcharfauros like this.
  13. Nov 5, 2018 at 6:29 AM
    m00seNUckLEz
    m00seNUckLEz tAc0 aFiCi0nAd0
    Fresno, CA
    Under Construction
    Sick. Looking to get some bypasses soon.
  14. Nov 5, 2018 at 8:48 AM
    TacomaGuy23
    Cody
    Holla at me when youre ready to order!
  15. Aug 6, 2019 at 1:43 AM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Sub'd. Will be going hydros in the near future to smooth out those bottom outs with a heavy bumper and tire gate. Spring over axle doesn't leave me much bump travel so gotta have it be plush!
    Question for you @TacomaGuy23, I saw another member testing a new mount for the 3rd gen Tacoma with a threaded, lock ring style bump from you guys. Is there an offering for that bump for 2nd gens? The website rear bump kit appears to be the pinch style.
  16. Aug 6, 2019 at 7:17 PM
    TacomaGuy23
    Cody
    Like me get with Riley and see what we have in the works!
    Supra4x4[QUOTED] likes this.
  17. Aug 7, 2019 at 1:09 AM
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    Sounds good! I've been looking around for a setup like this. OP says you're out of Temecula, I'm out of Mira Loma, only a 40 min drive down the 15 S! Would definitely be willing to drive down to make it work.
  18. Sep 25, 2019 at 1:59 PM
    literallynothing
    literallynothing I tow my new truck around with my old truck
    Noah
    2017 DCSB
    Steel and 37s
    I saw that you now offer a threaded option for adjustability. Is there a bracket on the back side of the can that can be welded to the frame?
  19. Oct 7, 2019 at 11:07 AM
    cesar_559
    cesar_559 New Member
    Cesar
    You guys still selling the 2" Pin Style + Mounting Sleeves for $360?
  20. Oct 7, 2019 at 11:09 AM
    literallynothing
    Noah
    2017 DCSB
    Steel and 37s
    I talked to them on another platform and whoever it was running TW disappeared and they don’t have access to message on here
