Locked steering wheel- key won't turn
Discussion in '1st Gen. Tacomas (1995-2004)' started by jermanjaysfan, Mar 25, 2011.
  1. Mar 25, 2011 at 7:03 AM
    jermanjaysfan
    jermanjaysfan [OP] Member
    Canada
    03 PreRunner 4x2
    Hey guys, wondering if you could help me with a bit of a problem:
    Last night I let my roommate move my truck (03 Prerunner) so he could get his car in the lane. I find out this morning that he left the wheels turned nice and sharply left, meaning that my key didn't want to get in the ignition this morning. I tried turning the wheel back around to get the key in, and was successful. However, in the process the wheel locked (at right about dead center). So long story short: steering wheel is locked, key goes in but won't turn.
    I tried jerking the locked wheel around a bit while trying to turn the key with no luck- I might try that again later when I get home. Failing that- any reccommendations? Is there a way to release the lock if I pop the steering wheel off? Would physically shaking the truck release the locking mechanism?
    Thanks in advance guys- you've helped me out before, and I appreciate it.
  2. Mar 25, 2011 at 7:08 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You ought to be able to do just by taking pressure off the wheel by moving it.
    Failing that, try jacking up the front end to take the pressure off the steering column.
  3. Mar 25, 2011 at 7:31 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Just move the wheel slightly and the key should turn. You just have to wiggle the steering wheel a little while trying to turn the key.
    If that fails...then do what Bjmoose said and and jack the front end up off the ground, then repeat step 1.
  4. Mar 25, 2011 at 7:42 AM
    Taco Erik
    Taco Erik Well-Known Member
    Erik
    Phoenix, ARIZONA 602
    2004 tacoma totalled, new 2005 Tacoma
    3" toytec coils with Bilstein 5100 shocks, camburg uca's, 1" AAL, Uws toolbox, 12" kicker sub system, flowmaster super 40s, more mods to come new build
    If you have an automatic there should be a little piece above the park that will pop out use a knife or flat head screw driver and push the piece inside that moves it will free up the shifted put it in neutral and it should turn? It happened to me once and my neighbor we were sucessful. Try it no guarantees but worth it to try
    bruinblizzard likes this.
  5. Mar 25, 2011 at 7:43 AM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    ^this fasho
  6. Mar 25, 2011 at 9:48 AM
    jermanjaysfan
    Canada
    03 PreRunner 4x2
    Alright thanks for the tips guys. Guess I'll just have to muscle it out a bit more when I get home.
  7. Mar 25, 2011 at 12:09 PM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    Yep, turn it hard in the direction the wheels are pointed and the key will turn.
  8. Jul 16, 2016 at 7:09 PM
    bruinblizzard
    bruinblizzard New Member
    2015 Silver Prerunner SR5
    Nerf Bars, Plasti Dip emblems & rims
    This was a life saver thanks!!!
