Locked up 2.7
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gamecock, Mar 12, 2024.
  1. Mar 12, 2024 at 4:45 AM
    gamecock
    gamecock [OP] Member
    Wayne
    SC
    08 PreRunner
    I just purchased an 05 2.7 auto 2wd. The engine is locked up. I am in the process of pulling the engine. I won't be able to take the torque converter loose from the flywheel since the engine will not spin. My question is, will the torque converter come out with the engine or do I have to pull the transmission also?
    Additional info on the engine. All accessories including the starter have been removed and it's locked up. I am guessing it ran hot. When I removed the valve cover I noticed that the cams were rusted pretty bad
