Locker Anytime Mod for Dummies 2005+
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jsi, Nov 30, 2014.
  1. May 18, 2018 at 8:58 PM
    #381
    davies604
    davies604 Well-Known Member
    Marcus
    vancouver
    Black On Black TRD OFF-ROAD
    285/75/16 Dura Tracs 3" OME full suspention lift Dakars in rear light Racing control arms 1" 1/4 Spider wheel spacers Blacked powder coat stock wheels Magna flow pro of road cat back K&N cold air
    I need help, forgive me if I’m stupid but
    Im totally stuck . Truck is 2005 tacoma from America 4.0 .
    My first issue was that my plug was not the same one you showed.... second issue was that rather then my pins going 1 2 5 6 they went 6 5 2 1 all my stuff was a mirror image of what you show ... I’m absolutely stupid or my trucks a lemon .... anyways I used the same colours you used I put them in the same place on the relay but now my 4x4 lights lockers lights and abs lights are all on , I cant engage 4x4 or the locker the only thing I can do is unplug the relay and then I’m stuck in 2 wheel drive , the one thing that is working is when I hit the locker button the relay clicks and it’s light turns green .... please help this noob!
    TXpro4X4 likes this.
  2. May 18, 2018 at 9:46 PM
    #382
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    I've been drinking.
    A friend in later posted had the same issue.
    I will try 4 you in the morning hopefully to tag and post you
    6 speed?
  3. May 19, 2018 at 1:44 PM
    #383
    jsi
    jsi [OP] Well-Known Member
    native earthling
    I think you are close and maybe it's just a cross up on the wires. The drawing shows the front of the plug, but I can now see how that could be confusing. Your plug looks just like mine. I've inset a shot of mine next to yours.
    Here's a drawing from the wire side of the plug
    Hopefully this is a little clearer. The front and back of the plug are mirror images. Check that the correct wires are going to the right places and let us know what happens.
  4. May 19, 2018 at 3:00 PM
    #384
    1E7DCSB
    1E7DCSB Well-Known Member
    NH
    Finally got around to doing it to my 07 last week. I made my “Y” and ground cable the day before and got it done fairly quick after work one day. Works awesome! Thanks again for the write up and relay.
    Took a few pictures
    F3638CB3-11AC-43B0-9A8C-7A19B8CB3CEE.jpg B21B9A9C-B83E-45C1-9FE2-6BB3A7304615.jpg 4B63369C-597C-4FDD-86B9-4052996EE83F.jpg
    I did the tests like the how-to said, but I wanted to make sure lol
    TXpro4X4 and jsi[OP] like this.
  5. May 20, 2018 at 10:49 AM
    #385
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    :burnrubber:
  6. May 20, 2018 at 6:41 PM
    #386
    davies604
    Marcus
    vancouver
    Ok ok ok I messed around a little more replaced my 4x4 fuse all is good but burnt out the locker ....
    Do you figure there’s any chance my grey wire mod caused the locker to overheat or did I do somthing wrong rebuilding the locker actuator ? My 4x4 hi and low work since installing locker mod and putting new fuse in ...so Im Leaning towards I messed somthing up with rebuilding and installing the actuator wrong
  7. May 20, 2018 at 9:04 PM
    #387
    jsi
    native earthling
    Dang, that looks ugly. Isn't the gray wire mod a 1st gen thing? I know there was another 2nd gen mod that tricked the truck into thinking it was in 4 low all the time. I never looked at mixing the two.
  8. May 20, 2018 at 9:21 PM
    #388
    davies604
    Marcus
    vancouver
    I did the locker mod with relay just referred to it as grey wire
  9. May 21, 2018 at 9:32 PM
    #389
    jsi
    native earthling
    I'm hoping someone else can jump in here. It's hard to tell from the picture, but it looks like the wiring to the relay might be wrong. Double check that the correct wires were cut and plugged into the right pins on the relay.
  10. May 21, 2018 at 9:49 PM
    #390
    davies604
    Marcus
    vancouver
    1 green / black 2 Y cable
    3 y cable 4 pink
    5 big green 6 big blue
    7 red / black 8 ground
  11. May 21, 2018 at 10:16 PM
    #391
    davies604
    Marcus
    vancouver
    I did just swap 7 and 8 I wonder if having that backwards could have fried the locker motor
  12. May 22, 2018 at 6:32 AM
    #392
    1E7DCSB
    NH
    It could have since it wasn’t grounded correctly. Have you tried cleaning up the copper wire on there, put it back in, and checked the fuses?
    “Ground (if you are using a diode equipped relay it's important that 7 and 8 are connected correctly. If you do it backwards fuse ig1 no.2 will blow.)”
  13. May 22, 2018 at 6:51 AM
    #393
    davies604
    Marcus
    vancouver
    Well what happened the first time was I had it done the correct way it tells you then it blew the fuse anyways so I switched it to be the other way lol
  14. May 22, 2018 at 6:51 AM
    #394
    davies604
    Marcus
    vancouver
    I shouldn’t have done 2 jobs at the same time makes things to confusing to find the problem lol
  15. May 22, 2018 at 6:52 AM
    #395
    davies604
    Marcus
    vancouver
    The motors winding
    Is toast it broke in a couple
    Places going to order a new actuator today
  16. May 25, 2018 at 2:51 PM
    #396
    1E7DCSB
    NH
    Damn that sucks!
  17. Jun 1, 2018 at 4:12 PM
    #397
    davies604
    Marcus
    vancouver
    Ok I don’t get it everything did work but I killed my locker new one just arrived I doubled checked all connections to relay looked good grounds connected started truck and bam I had abs light on e break light on , my power windows won’t do anything my heaters won’t work , relay does not light up green when I hit locker button or engage 4x4 locker doesn’t work 4x4 does I am so confused checked fuses they all are good
  18. Jun 1, 2018 at 4:43 PM
    #398
    1E7DCSB
    NH
    Jeez that’s not good. I can’t even attempt to look at schematics until Monday at the earliest.
    Almost seems like something isn’t plugged in.
    I know you said you checked connections, but are any of your female connectors going onto the relay touching by any chance?
    When I was hooking mine up, the connectors were fitting loose onto the relay and a few were touching, but I tightened the connectors with pliers before plugging the main pigtail back in
  19. Jun 1, 2018 at 6:30 PM
    #399
    davies604
    Marcus
    vancouver
    Going to be a late night now I did use pliers on them before I will try again and install a new vampire
  20. Jun 1, 2018 at 7:32 PM
    #400
    davies604
    Marcus
    vancouver
    Ok I tightened all ends even taped them so there’s no chance of contact still , no green light in relay, no locker light, no power windows or heat I am so confused but 4x4 does work, abs and e break lights are on ..
