Locker Anytime Mod for Dummies 2005+
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jsi, Nov 30, 2014.
  1. Jun 1, 2018 at 8:50 PM
    #401
    davies604
    davies604 Well-Known Member
    Marcus
    vancouver
    Black On Black TRD OFF-ROAD
    285/75/16 Dura Tracs 3" OME full suspention lift Dakars in rear light Racing control arms 1" 1/4 Spider wheel spacers Blacked powder coat stock wheels Magna flow pro of road cat back K&N cold air
    Oh god and it gets worse , not only am I having electronic issues now so things draining my power and if I try to drive on the road the truck bogs out and all the lights dim , what have I done !
    TXpro4X4 likes this.
  2. Jun 2, 2018 at 9:31 AM
    #402
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    :notsure:
    I would disconnect the battery terminals put all the wiring back to stock reconnect the battery terminals and hope for the best.
  3. Jun 2, 2018 at 10:32 AM
    #403
    davies604
    Marcus
    vancouver
    Yeah Thats the next step , I’m thinking the trucks running back due to alternator or battery may just be bad timing ... as for e break and abs light I read online it could be the abs sensor that is attached to differential behind the locker
  4. Jun 2, 2018 at 10:33 AM
    #404
    davies604
    Marcus
    vancouver
    But windows and heat I don’t know ugh to much at once , could be a bad ground somewhere what I don’t understand is I had the relay working just fine until I installed the new locker only thing I did differently was spray the electronic connection with electrical cleaner before reconnecting
  5. Jun 3, 2018 at 8:33 PM
    #405
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Yhea weird!
    You are sure its the right part?
  6. Jun 3, 2018 at 8:38 PM
    #406
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Man and I thought I had bad luck with this mod!!
    Hope things pan out
  7. Jun 3, 2018 at 8:51 PM
    #407
    davies604
    Marcus
    vancouver
    Yes sir I ordered the relay with diode off Etsy from this forum , this is very odd to me i been working on my truck for 8 years with no issues but this mod and rebuilding locker have been nothing but fail after fail oh man , this week I guess I will clean all my grounds replace battery and if I had to put male ends on the wires and put it back to normal ... if I put a battery and put a wire to pin 7 and 8 should it light up the relay so I can test if it’s still working ?
  8. Jun 3, 2018 at 8:53 PM
    #408
    davies604
    Marcus
    vancouver
    I know my battery has been failing so it’s time for a new battery I also read that if I have bad grounds anywhere it can absolutely do all kinds of weird issues so fingers crossed
  9. Jun 3, 2018 at 8:57 PM
    #409
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Bad grounds are not good at all.
  10. Jun 3, 2018 at 9:50 PM
    #410
    anthony250f
    Anthony
    San Diego, CA
    When I was having issues with mine that’s exactly what I did. When it was back to stock everything worked fine so I KNEW it had to be the relay
  11. Jun 21, 2018 at 7:43 PM
    #411
    UTTOY
    UTTOY New Member
    2005 Toyota Tacoma TRD Off Road 4x4
    front leveling kit, front mounted receiver hitch.
    I did this modification exactly as the instructions show. The install was relatively easy and straightforward but for whatever reason, now I can't get the locker to lock-in. Tried driving slowly, turning back and forth, in forward and reverse. The little green light in the relay lights up, power is applied to the appropriate terminals (I think) and everything looks good but to no avail. not sure what my next step should be. Any ideas?
  12. Jun 21, 2018 at 8:11 PM
    #412
    anthony250f
    Anthony
    San Diego, CA
    Next step would be have someone hit the button while you lay underneath and listen to hear if the locker motor makes sound
  13. Jun 22, 2018 at 7:54 AM
    #413
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Welcome to T. World!
    I second this.
    If no noise put back to stock and try again. If it works again then something is not right with the relay or your wiring. Mine sometimes takes a min to lock. Moving the wheel back and forth going backwards and forwards blah blah blah. Don't happen quick 90% of the time.
    Good luck and let us know. All info is helpful!
  14. Jun 22, 2018 at 2:43 PM
    #414
    UTTOY
    UTTOY New Member
    No sound from the locker with relay. When relay is removed and wiring returned to stock, locker works just fine, both the indicator light and the locker locks up mechanically. I tripled checked the wiring and it's in accordance with the modification. Guess I'm back to stock condition (locker in 4LO only) but with a little more experience now.
  15. Jun 22, 2018 at 3:02 PM
    #415
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Where did you get the relay?
  16. Jun 22, 2018 at 3:08 PM
    #416
    1E7DCSB
    1E7DCSB Well-Known Member
    NH
    I think I’m now having issues with this mod. I just lost a lot of shit while driving including my windows working. Had to drive with the door open so I don’t die lol
    Mod has worked fine since I’ve done it and now I’m having issues with the whole truck fml
  17. Jun 22, 2018 at 3:11 PM
    #417
    UTTOY
    UTTOY New Member
    I bought the flyback diode from the link in the instructions. It's the one that is supposed to prevent voltage spikes. It was listed on Etsy.com for $18.
  18. Jun 22, 2018 at 3:30 PM
    #418
    1E7DCSB
    NH
    Same. I think mine has failed causing my issues. Going back to stock as we speak to see what happens. I clicked the button and the locker doesn’t light up on the dash now. Used to work fine
  19. Jun 22, 2018 at 3:35 PM
    #419
    1E7DCSB
    NH
    I think your issue was a bad relay now. I believe mine has failed. My speedometer is also out, hvac cut out, etc.
  20. Jun 22, 2018 at 3:49 PM
    #420
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    I have a feeling you right. Return to stock.
    If you would like for both of you I can snap a pic but I'm sure there is one in this thread somewhere already of the radio shack relay.
    The relay is 3-party member of you will. Not part of the system and it's sensors
    I used the 1 from radio shack and have had 0 problems as of yet.
    Even though I have used a different relay it doesn't mean that I am not going to have problems later on down the line the relay could ultimately failed somewhere.
