Locker Anytime Mod for Dummies 2005+
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jsi, Nov 30, 2014.
  1. Apr 20, 2019 at 7:50 AM
    #521
    04tacomarob
    04tacomarob Well-Known Member
    Robert
    Fallon, NV
    15 DCSB TRD OR and 04 Tacoma TRD
    Awesome man, thank you for the clarification on that and thank you for keeping up on this thread! For people who suck with anything electric (me!) this is a life saver!
    Edit:
    Works like a charm on the short test drive I did. All worked in 4hi/lo and 2wd. Relay worked as it should with the LED coming on once the locker was engaged.
    Spose after some actual driving we will see if my wiring and solder job will hold since it was my first time soldering. I did however end up soldering the Y into the purple wire instead of using a tap.
    Thanks again for this write up, 2wd locked is some of the best fun for me :p
    jsi[QUOTED][OP] likes this.
  2. Jun 2, 2019 at 5:57 AM
    #522
    87-98-08tacoma
    87-98-08tacoma New Member
    Good morning. When adding the replay listed above. Where do you add the diode???
    TXpro4X4 likes this.
  3. Jun 2, 2019 at 6:34 AM
    #523
    Jpiskura
    Jpiskura Well-Known Member
    This mod will not work on a TRD Sport then..?
  4. Jun 2, 2019 at 12:02 PM
    #524
    jsi
    jsi [OP] Well-Known Member
    native earthling
    This only works with the factory locker installed in the Off Road model.
    Sorry
    Norton likes this.
  5. Jun 2, 2019 at 12:36 PM
    #525
    Jpiskura
    NP thanks!
  6. Jun 6, 2019 at 8:42 PM
    #526
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Welcome to Taco world
    I didnt use it. Hopefully someone that does will respond
    Edit. On the first page he has a you tube video on how to install the diode.
    Good luck. I need to do the same I guess
    :pout:
  7. Jun 7, 2019 at 6:49 PM
    #527
    jsi
    native earthling
    Sorry - missed your post. The video linked in the first post shows how to make your own. HOWEVER, and this is important, depending upon the relay you use there are differences and need to be considered. If you get it wrong fuses will be blown. If you're game to try post here. I'll try to pay better attention.
    My life is in boxes right now and I can't make a better video, but once I'm moved into my new place getting the instructional video sorted out is on the top of my list.
    SR-71A and TXpro4X4 like this.
  8. Jun 8, 2019 at 3:14 PM
    #528
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Should a diode be installed on all relays?
    Or is there a relay that already has it installed?
  9. Jun 8, 2019 at 8:22 PM
    #529
    jsi
    native earthling
    The short answer is yes. The slightly longer answer is electrical engineers take all of this into account when designing a circuit, but when we add a relay it is up to us to mitigate the voltage spike. Water flowing in pipes is a good analogy for electricity. When you shut flowing water off quickly you will get a water hammer and the pipes will bang and valves get damaged. When you quickly shut off electricity flowing through a coil there is a voltage spike that can easily damage electronics.
    I was/will be again making and selling a relay with the diode correctly installed. I've searched high and low looking for a pre-made option with no luck at all. That's why I started making them myself. And, with all of that said I ran mine without a diode for quite a while without any issues. In the scheme of things it's not like the relay gets used a lot.
    Norton and TXpro4X4[QUOTED] like this.
  10. Jun 8, 2019 at 9:21 PM
    #530
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Ok good to know!
    Plz post when you have some ready to go!
    I use mine often because I go by the saying.
    If you dont use it you could loose it
    MoDuMan and jsi[QUOTED][OP] like this.
  11. Jun 9, 2019 at 9:37 AM
    #531
    87-98-08tacoma
    Could the diode be installed into the wire that plugs into that prong ????
  12. Jun 28, 2019 at 7:12 PM
    #532
    MoDuMan
    MoDuMan Member
    Tacoma Limited 2017
    Bed camper shell
    Great post. Good explanation and great rant. I think I will stick to rule#1 and just put the truck in 4WD-Lo if I need to rather than doing all of this. I belong to rule #9 --- take the easy way out and use the truck's stock features.
    jsi[OP] and TXpro4X4 like this.
  13. Jun 30, 2019 at 11:32 PM
    #533
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Sure....but what about doughnuts?
    Lol
    jsi[OP] likes this.
  14. Nov 23, 2019 at 5:14 AM
    #534
    R77toy
    R77toy Well-Known Member
    2015 DCSB Pyrite 4x4 Off-Road
    Does anyone have a source for the relay with the diode?
  15. Nov 23, 2019 at 12:10 PM
    #535
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    @jsi
    Made any of those yet?
    I could use one myself even though no issues yet.
  16. Dec 6, 2019 at 8:22 AM
    #536
    GregoryS10
    GregoryS10 Well-Known Member
    Gregory
    Casper WY
    2015 tacoma TRD off-road
    I would also buy one if someone has one.
  17. Dec 6, 2019 at 8:11 PM
    #537
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Yo!
  18. Dec 13, 2019 at 8:02 PM
    #538
    DraculaS2k
    DraculaS2k Active Member
    2011 ac trd off road
    4.88s, air lockers, 3" ,33s mt, snorkel,
    Can you make video bout this on your YouTube channel. I got Lost in the whole process lol
  19. Dec 13, 2019 at 8:55 PM
    #539
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    He is lurking but not responding for some reason
    Do you have 4x4?
  20. Dec 14, 2019 at 9:22 AM
    #540
    jsi
    native earthling
    I'm still around, sort of. Life = Crazy. It's all good but there is little time for anything but projects. I was going to get back to this in the fall, but life . . .
    Anyway, My plan is to get going again January 11. The projects should be done by then
    I made a youtube video. I'm not real happy with it because the diode install is backwards from what the instructions say above. And If you get it backwards fuses blow.
    I've updated the video so it matches the instructions on the first post.
    SR-71A and TXpro4X4[QUOTED] like this.
