Locker Anytime Mod for Dummies 2005+
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jsi, Nov 30, 2014.
  1. Feb 2, 2015 at 9:31 AM
    #61
    Thelgord
    Thelgord The Pantagonist
    Augusta, GA
    '13 TRD (OffRoad, 4x4)
    SOS Rocksliders, All Pro skid plate, Procomp add-a-leaf, Bilstein 5100 @ 1.75", CB, high-lift jack
    He says in a post ...
  2. Feb 2, 2015 at 11:50 PM
    #62
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    I just finished this mod and everything works great EXCEPT now the locker light won't turn on... Does anyone know which connections I should check to fix this? I'm 99% sure I have everything in the right place so I think when I crimped on one of the female connectors, I squished the wire coating and not the wire. Thanks!
  3. Feb 3, 2015 at 12:35 AM
    #63
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    You don't mess with the wire that goes to the dash indicator so if you touched that you def screwed something up. It's a blue wire with yellow stripe. My guess is that the locker isn't working or you cut into the wrong wire and disconnected the light from the dash.
  4. Feb 3, 2015 at 7:26 AM
    #64
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Well I know for sure I didn't touch a blue wire with a yellow stripe, maybe it accidentally got pulled out when I was moving the wires over. But I know the locker works for sure, I can hear it click on and did the tire rub test in 2hi 4hi and 4low so I know the locker is working, thanks for the info on that wire though
  5. Feb 3, 2015 at 8:22 AM
    #65
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    And half of those half probably don't even have the Elocker anyway.
  6. Feb 3, 2015 at 12:47 PM
    #66
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Anyone else have any advice?
  7. Feb 3, 2015 at 2:10 PM
    #67
    PSU Taco85
    optional
    what is the "tire rub test"? Are you sure the rear diff is locking in?
    The only other thing I'd recommend if you are sure you hooked it up right would be to pull the locked indication switch off the diff and have a buddy press the ball part of the switch in and see if you get the dash light.
  8. Feb 3, 2015 at 2:41 PM
    #68
    Traviste
    Traviste Now with more woopow
    Travis
    Georgia
    2014 DCSB Locked 4x4 Mid-Travel
    F:King 2.5 coilover resi ext 700#coils R:King 2.5 ext allpro expos
    Worked on my 2014
    THANKS
  9. Feb 3, 2015 at 3:23 PM
    #69
    whahahajr
    whahahajr Lone Star Club
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Camburg Uniball UCA, ARB Front Bumper, TAG rear bumper, OME rear shocks, All Pro 3" leaf springs
    I don't think the light turns on till it actually locks in. Push the button turn left and right while slowly moving till it locks. Then the light should come on.
    subbed
    This may be a sin posting another forum but look at post # 20
    http://www.yotatech.com/f117/05-taco-locker-mod-81241/
    Possible the locker switch?
  10. Feb 3, 2015 at 3:57 PM
    #70
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Yes that is exactly my problem, the light will come on when I start the car and not when I try to engage it, thanks for posting that! I'll just end up getting a new switch sometime.
    Code Black likes this.
  11. Feb 3, 2015 at 4:02 PM
    #71
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    When I say the "tire rub test" I mean turning on the locker while in 2hi and 4hi and then drive slow and make a sharp turn so you can hear/feel your tires "skipping" or "rubbing" as its trying to go the same speed as your other tire. Anyways mine did do this so I know for sure the mod worked. Like I said earlier I'll probably just end up replacing the switch with a covered toggle switch so it's easier to visually see whether it's on or not.
  12. Feb 3, 2015 at 6:56 PM
    #72
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Does anyone know if after doing this mod, it will also turn off your abs anytime the locker is on? I was looking into doing the abs mod also but it sounds like I may not need to if I would only want it off when my locker is on.
  13. Feb 3, 2015 at 9:55 PM
    #73
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Awesome thanks
  14. Feb 3, 2015 at 10:16 PM
    #74
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
    Great write-up.
  15. Feb 7, 2015 at 4:44 PM
    #75
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Just Did. 2014 model. Only wire color difference was the red/black was more maroon/black. All the other instructions are exactly correct.
    Great Work OP!!
    ItsRichieRich likes this.
  16. Mar 15, 2015 at 3:35 PM
    #76
    TheStevo
    TheStevo Baja Taco Enthusiast
    Stevo
    Reno, NV
    MAGNETO
    TC +3.5 LT, Fox COs, King Bypasses, DTF SUA w/ 3x18 Quad bypass, Fox Air Bumps, Method 17" NVs, 35s, Relentless Fab custom tube bumper, skids, & sliders, lots of LEDs
    Did this on Friday, I should have done it years ago. Makes for waaayyy more sideways fun offroad!!!
  17. Mar 15, 2015 at 3:39 PM
    #77
    sixspeedlife
    sixspeedlife Well-Known Member
    Braden
    MB, Canada
    05 TRD OFFROAD Six speed
    Leveled, BHLM, Black mesh grill, black skid plate
    Aren't you gunna break stuff going over 5mph?
  18. Mar 15, 2015 at 3:48 PM
    #78
    TheStevo
    Stevo
    Reno, NV
    MAGNETO
    No only if you engage it while driving over 5mph, or while your wheels are spinning. I was driving 65+ with it locked (on dirt).
  19. Mar 15, 2015 at 4:01 PM
    #79
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Is it dangerous/sketchy going that fast if you turn at all?
  20. Mar 17, 2015 at 12:34 PM
    #80
    TheStevo
    Stevo
    Reno, NV
    MAGNETO
    No, not unless you're turning aggressively while hammering the throttle (i.e. drifting), but even when drifting it's quite manageable when you're on dirt/sand/gravel. Way more fun too! :D When the diff lock is engaged the ABS is disengaged, but that's not really a big deal either when you're on dirt. I wouldn't try any of that on the street...
